Input_datetime
I have two variables declared in configuration.yaml:
input_datetime:
nextcooldperiod:
name: “Prochaine periode froide”
has_date: true
has_time: true
coldperiodeduration:
name: “Duree periode froide”
has_date: false
has_time: true
I see the variable coldperiodduration in the developpement tool.
My script is:
alias: "cold_period"
    platform: time
    at: input_datetime.nextcooldperiod
  - service: notify.email
      title: "Home assistant warning"
      message: "Evenement periode froide Hydro Quebec"
  - service:  input_boolean.turn_on
      entity_id: input_boolean.over_heating
 # - delay: '00:55:00'
  - delay: '00:00:10'
      message: "will turn off over heating "
  - service:  input_boolean.turn_off
      message: "Will tunr on save electricity"
      entity_id: input_boolean.save_electricity
      message: "Duration of the cold period: {{input_datetime.coldperiodeduration}} "
  - delay: input_datetime.coldperiodeduration
      message: "Fin de la periode froide Hydro Quebec"
And, I have followings error in logs:
Logger: homeassistant.components.automation.cold_period
Source: helpers/service.py:140
Integration: Automatisation (documentation, issues)
First occurred: 10:45:01 (2 occurrences)
Last logged: 10:45:01
cold_period: Error executing script. Unexpected error for call_service at pos 8: Error rendering data template: UndefinedError: 'input_datetime' is undefined
While executing automation automation.cold_period
  File "/usr/src/homeassistant/homeassistant/helpers/template.py", line 421, in async_render
    render_result = compiled.render(kwargs)
  File "/usr/local/lib/python3.8/site-packages/jinja2/environment.py", line 1090, in render
    self.environment.handle_exception()
  File "/usr/local/lib/python3.8/site-packages/jinja2/environment.py", line 832, in handle_exception
    reraise(*rewrite_traceback_stack(source=source))
  File "/usr/local/lib/python3.8/site-packages/jinja2/_compat.py", line 28, in reraise
    raise value.with_traceback(tb)
  File "<template>", line 1, in top-level template code
  File "/usr/local/lib/python3.8/site-packages/jinja2/sandbox.py", line 407, in getattr
    value = getattr(obj, attribute)
jinja2.exceptions.UndefinedError: 'input_datetime' is undefined
  File "/usr/src/homeassistant/homeassistant/helpers/service.py", line 138, in async_prepare_call_from_config
    service_data.update(template.render_complex(config[conf], variables))
  File "/usr/src/homeassistant/homeassistant/helpers/template.py", line 99, in render_complex
    return {
  File "/usr/src/homeassistant/homeassistant/helpers/template.py", line 100, in <dictcomp>
    render_complex(key, variables): render_complex(item, variables)
  File "/usr/src/homeassistant/homeassistant/helpers/template.py", line 104, in render_complex
    return value.async_render(variables)
  File "/usr/src/homeassistant/homeassistant/helpers/template.py", line 423, in async_render
    raise TemplateError(err) from err
homeassistant.exceptions.TemplateError: UndefinedError: 'input_datetime' is undefined
  File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 253, in _async_step
    await getattr(
  File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 432, in _async_call_service_step
    domain, service, service_data = async_prepare_call_from_config(
  File "/usr/src/homeassistant/homeassistant/helpers/service.py", line 140, in async_prepare_call_from_config
    raise HomeAssistantError(f"Error rendering data template: {ex}") from ex
homeassistant.exceptions.HomeAssistantError: Error rendering data template: UndefinedError: 'input_datetime' is undefined
What’s wrong ?
Thanks for your help !
I prefer to declare stuff like input_datetime as an helper in the configuration, you’ll get dialogs to configure it, here:
Much easier for the beginner that I am.
Else make sure it exists in dev tools / states, look for input_datetime.nextcooldperiod. If it doesn’t exist, it’s a bad YAML configuration
I believe the problem you have reported here is related to a problem you have posted in two other places:
This is incorrect:
In your other posts, this is also incorrect:
- delay: {{states(‘input_datetime.coldperiodeduration’)}}
Change it to:
- delay: "{{states('input_datetime.coldperiodeduration')}}"
For the record, the post you have marked as being the Solution (i.e. use Configuration > Helpers to create an input_datetime entity) doesn’t solve the problem you reported.
It doesn’t matter if you define the input_datetime via the UI or in configuration.yaml. The problem is that the template using the input_datetime is incorrect.
In addition, I’ve noticed you have attempted to mark several posts within the same thread with the Solution tag. This is not possible. Only one post in a thread can have the Solution tag.
thanks for your reply.
I was very disapointed, but now I have solved the automation.
Best regards
