With Helpers, it would be nice if, in addition to the value for initialization, I could also determine what happens to the value when HA is restarted.
input_number:
slider1:
initial: 30
The documentation says:
initial float (optional, default: The value at shutdown)
Initial value when Home Assistant starts.
If I understand correctly, I only have the choice of specifying a value for initialization today, to which the helper is always reset when HA is restarted.
If I don’t specify a value for initialization, the helper will keep its value if I restart HA.
It would be nice if I could enter a starting value, but this value is only used for the first initialization. The set value is retained when the system is restarted.
Or is there already a way to achieve that today that I don’t know?
