It is possible to put input_number yaml files in one folder like sensor and switches?
I try like this, but not working:
input_number: !include_dir_merge_list components/input_number
Yes you can. Did you remove the “input_number:” in the files in the input_number folder and did you create the input_numbers as a list?
Could you please show one of the files in the folder input_number?
try this:
input_number: !include input/input_number.yaml
and create a directory callend input. put your input_number.yaml inside that.
This will also work, but it is not the same way as OP asked, so I’m not sure if this will be ok for him.
There is a file:
## INPUT NUMBER - ENERGY COSTS
#https://www.home-assistant.io/components/input_number/
# 10.12.2019
bathroom_wash_and_dry_daily_cost:
mode: box
min: 0
max: 100
unit_of_measurement: "EUR/day"
icon: mdi:currency-eur
bathroom_wash_and_dry_energy_cost:
mode: box
min: 0
max: 100
unit_of_measurement: "EUR/kWh"
hallway_climate_daily_cost:
mode: box
min: 0
max: 100
hallway_climate_energy_cost:
mode: box
min: 0
max: 100
cumulative_energy_cost:
mode: box
min: 0
max: 5000
unit_of_measurement: "EUR"
## END
Then use an named merge not a list merge.
Like this:
input_number: !include_dir_merge_named components/input_number
Now is working thanks.
For more info and examples check out this:
