I would like to send ir command to my av receiver when I change the chromecast volume slider from 0.
What is the right trigger command?
Thank you!
Thank you!
This will trigger for any change of the input_number.
platform: state
entity_id: input_number.your_vol_silder_name
If you only want it to trigger when moved from 0 this might work (untested) :
platform: numeric
Otherwise you could try:
platform: state
condition: template
value_template: "{{ trigger.from_state.state == 0 }}
That won’t work as numeric isn’t a valid trigger and the valid numeric_state trigger appears to not use the ‘from’ attribute.
the correct syntax would be:
- platform: state
Thank you for your reply.
I got it working with this one:
- alias: 'Radio on'
platform: numeric_state
entity_id: input_number.volume_radio
above: 0
and off command:
- alias: 'Radi off'
below: 0.1
That also works, that’s the correct numeric_state trigger. Just keep in mind, that automation will fire every time the slider is above 0. So if you move from 1 to 44 it will fire.
Actually, it won’t. It will only fire when it changes from 0 or below to above 0. (And there’s a special case at startup - it will fire for the first state change if the new value is above 0, even if the previous value was not 0 or below.)
I actually spent some time digging pretty deep into this one because at first I incorrectly decided the docs were wrong and made some incorrect comments on this forum to that effect, although I did try to go back and correct those misstatements.
Ah, good to know. I may have read that from one of your posts, or the docs. Not sure where. I use appdaemon for my automations so I’ve never used numeric_state before.
