Input Number Display mode as Input Field
Not 100% certain if this belongs in this category, but here is my issue, which is rather weird:
I am managing 4 instances of homeassistant across several homes for my family
To make the fine-tuning of certain behaviors a bit easier for the rest of the family, I mostly use input numbers in my automations so that I can expose only that part to them on the interface.
In 3 out of 4 of the installations (HassOS) I get the option to switch the display mode for an Input number from Slider to Input Field when I try to create a new input helper, or when I go into the settings menu of the relevant input number.
However, on the 4. instance, this option isn’t shown, no matter what I try. All of them run on the same hardware and are on the same version of HA, and the issue has been persisting across multiple updates, so I’m pretty sure this is a matter of configuration in some hidden menu. Does anyone have an idea where this setting could be buried?
did you ever figure this out? I added a couple of input_number entities for manually track meter readings and there i can’t see any option to change the input mode. I can manually set it to box in the developer tools with YAML but then it goes right back to a slider when i update it
I have this same issue, that I cannot change “mode” of input number in UI.
As a workaround I changed “mode” in configuration file (/[home assistant config folder]/.storage/input_number) and restarted home assistant.
.storage is hidden folder and it contains (among other things) configuration files for helpers (one file for each helper type).
This way “mode”-change should persist.
Very late reply but have you switched your user to advanced mode?
To do that click on your user account image on the left bottom and search for the advanced mode.
