Input number for automation, error
Hi, I would like to add the chance to change a default timing set for an automation, creating a slicer on lovelace. I’ve seen that is possible using the input_number. I’ve tried with the following configuration but I’m getting this error:
Invalid config for [automation]: expected float for dictionary value @ data['for']['hours']. Got None expected float for dictionary value @ data['for']['minutes']. Got None.
configuration.yaml
input_number:
  hours:
    icon: mdi:clock-start
    initial: 1
    min: 0
    max: 3
    step: 1
  minutes:
    initial: 15
    min: 0
    max: 60
    step: 5
automations.yaml
- id: '1670488106467'
  alias: Termocoperta_1ora
  description: Spengo la termocoperta dopo 1 ora dall'accensione
  - platform: device
    type: turned_on
    device_id: 84a0f117d9dfe632aa10123865117f47
    entity_id: switch.termocoperta
    domain: switch
    for:
      hours: "{{ states('input_number.hours') | int(0) }}"
      minutes: "{{ states('input_number.minutes') | int(0) }}"
      seconds: 0
  condition: []
  - type: turn_off
    domain: switch
  mode: single
What should I do in order to fix it?
Thanks!
Marco
I’ve fixed adjusting the automation as follow:
  - platform: state
    to: 'on'
    for:
      hours: "{{ states('input_number.hours') | int }}"
      minutes: "{{ states('input_number.minutes') | int }}"
  condition: []
  - type: turn_off
    domain: switch
  mode: single
Now I’ve to found an alternative solution that guarantee me to change the running timer when the device has already been activated. Because with this structure using a ‘for’ I haven’t any leverage on timing once it has been turned on.
As you have found, device triggers do not support templates. There are other reasons for avoiding device triggers, conditions and actions:
