Input_number in automation above/below fields not working
i’m studing HA automations… i read in this guide
automation:
    platform: numeric_state
    entity_id: sensor.temperature
    # input_number entity id can be specified for above and/or below thresholds
    above: input_number.temperature_threshold_high
    below: input_number.temperature_threshold_low
but when i try this example i get the error
Message malformed: expected float for dictionary value @ data['above']
is it a bug or something outdated in the guide?!
thanks
More likely you have an outdated homeassistant installation. The docs always refer to the latest available release, and the ability to use input numbers there are part of the most recent release as of yesterday.
i’m using the latest release…
If you’re using 2021.2.0 and you’re still getting this error then you need to create a bug report.
Hang on, where is this code ?
Another observation here is that the code quoted is exactly a lift from the docs, presumably you actually have these two input numbers defined somewhere?
ok, thanks @anon43302295. i’m just doing a fresh install to verify the problem in a brand new environment…
@Mutt
automations.yaml
-  alias: 'test atomation'
     - platform: numeric_state
       entity_id: sensor.thermometer_t0000_temperature
       above: input_number.aaa
    - service: notify.persistent_notification
         title: 'test title'
         message: 'test message'
  mode: single
entity and helpers have been properly created
(messed up the code above but yaml file is ok…)
Well : -
automation:
Does not live in automation.yaml
And as Marc said. Have you created the two input_numbers ?
Okay
Do you have sensor.temperature ?
And what is messed up.?
Where is the alias or the id ?
@anon43302295: really thank you. reinstalled right now the HA image, put back on the yaml and the automation has been created… gone crazy for a couple of days trying the example.
Yeah, I suspect that you were unlucky and downloaded the previous version just after the docs were updated, but just before the new version was available for download.
Not to worry, so long as you’re up and running :slightly_smiling_face:
