Input_Number in automation
#if the temp is under the slider value, trigger stuff
- id: test1
  alias: test1
  - platform: numeric_state
    entity_id: sensor.0x00158d0001b9122f_temperature
    below: 'input_number.test1'
    for: '00:00:01'
    - service: notify.home
      data_template:
        message: "testing success"
Slider to control my automation parameter. But I got an error:
[homeassistant.config] Invalid config for [automation]: expected float for dictionary value @ data['trigger'][0]['below']. Got 'input_number.test1'.
This may just be a simple programming error, any help is appreciated
You cant use an entity id in below: It only accepts numbers.
You can use a template trigger:
    value_template: "{{ states('sensor.0x00158d0001b9122f_temperature') | float < states('input_number.test1') | float }}"
    for: '00:00:01'
Thanks! Will try that out later
