I am trying to configure my lights so they show a slider in the frontend, instead of the current setup where I have to press the light to get to the slider.
I have added the following code to my configuration.yaml
input_number:
Thanks what I’m thinking too, I didn’t know if there was a way to trick HA into thinking it was a bulb. Thanks for your reply, I’ll probably just add a dimmer knob to the cord of my lamp that I’m trying to dim. The issue is it’s small leds and I’m not sure if they can be dimmed or not.
You could trick HA into thinking it’s a bulb but that wouldn’t allow HA to dim it as the hardware doesn’t allow it, you would need a special LED dimmer control.
i did try a dimmer extention cord but it made my lights flicker like a strobe light. So I might be out of luck. I like the lamp but i think its way too bright.
it was for leds, but i believe it was for standard screw in type bulbs. Do you think I would get the same result if i spliced a regular dial dimmer on the power cord?
