First time asking for some help… Thanks in advance as I learn…
I’m trying to create a input_number (slider) form that will be used to update a value in my automation. It seems that even though I slide/change the number, the automation doesn’t seem to catch the change. Is there something that maybe i’m missing to ensure that once the value is changed, the automation finds the latest number. It works when i manually run the automation, but it’s not changing when i change it via lovelace frontend. Any help would be appreciated. THANKS!!!
Here is the helper setup from the UI
input_number.freezer_set_point - slider, my input value that then feeds to the automation, using this is a numerical value
- id: '1648562250730'
alias: Activate Freezer alarm (HIGH TEMP)
description: ''
- platform: numeric_state
entity_id: sensor.bme280_2_temperature
above: input_number.freezer_set_point
condition: []
- service: switch.turn_on
data: {}
entity_id: switch.red_led2
- service: notify.whatsapp_mark
message: FREEZER HOT
- delay:
hours: 0
minutes: 0
seconds: 30
milliseconds: 0
mode: single
