I have this card in Home Assistant and also have an automation in node-red to trigger the humidifier when the humidity is > 65 but I want to use the input_number slider in node-red but this doesn’t works.
I’m using the global variable to check the condition.
I’ve tried with:
Hi jandrop
This is a really simple question, but I’ve wasted hours on it. How did you convert the string to a number? I’ve experimented and keep getting error messages whenever i try and use a pipe operator.
