after having removed secondaryinfo-entity-row card, because it explicitly needs to load the card-tools in resources, I’ve yet found another reason to re-install it again…
It seems to be the only card that can show a secondary line with another entity, without losing the slider of the main input_number entity. See below:
- input_number.front_room_lux
- type: custom:multiple-entity-row
entity: input_number.front_room_lux
secondary_info:
entity: sensor.front_room_sensor_light_level
unit: lx
- type: custom:template-entity-row
secondary: >
{{states('sensor.front_room_sensor_light_level')}} lx
- type: custom:secondaryinfo-entity-row
secondary_info: >
Current: [[ sensor.front_room_sensor_light_level.state ]] lx
which shows as:
maybe I am incorrectly using the yaml configs, so that’s why I post here, maybe anyone could spot an error. Or simply have another suggestion?
If not, this is for reference and help to other forum members seeking what I did.
btw, not visibile here: as often the sliders don’t show their states, the quick test with this secondaryinfo card above always kept showing it, while the others showed a blank state position.
