Hello to all.
I would like to create an automation that allows me to switch on a device based on a comparison of two values. One of them is a temperature and one is a number that varies.
I set the variable number
Numeric state trigger will only fire when sensor.0x00158d0005343cf0_temperature goes from below input_number.camera to above input_number.camera.
Fires when the numeric value of an entity’s state (or attribute’s value if using the attribute property, or the calculated value if using the value_template property) crosses (and only when crossing) a given threshold. On state change of a specified entity, attempts to parse the state as a number and fires if the value is changing from above to below or from below to above the given threshold.
It will probably not fire immediately after you change input_number.camera, it will have to wait until the state of sensor.0x00158d0005343cf0_temperature changes to notice that it’s above the threshold.
Error loading /config/configuration.yaml: while parsing a block mapping
in “/config/automations.yaml”, line 593, column 5
expected , but found ‘’
in “/config/automations.yaml”, line 594, column 33
In the first automation nothing happens the light does not activate even waiting for time. I would like it to turn on when the temperature is greater than the input value which varies depending on the case. Thanks
Maybe I solved … since I was performing I try I had two automations with two identical names: Testina on
Now I changed the name by correcting the "and I have no more errors. Thanks
I have another problem … with both automations I do not reach the desired result. If the sensor temperature has already exceeded the input number and the vario x turn it back on, this does not happen. I would need the checking of the two values to happen constantly over a certain time so that this can always create the event.An advice?
Add a state trigger for input_number.camera and a numeric state condition (same condition as the first trigger).
This will cause the automation to run again every time you change input_number.camera and the condition is fulfilled. Is this what you want?
