Input_numbers and problem publishing mqtt
Hello everybody.
I can’t get the values ​​I select with the cursor to publish. Where am I wrong? I’m going crazy…
## configuration.yaml
input_number:
  target_temp:
    initial: 26
    min: 18
    max: 30
    step: 1
## automation.yaml
automation:
  - alias: "Temp slider moved"
      platform: state
      entity_id: input_number.target_temp
      service: mqtt.publish
        topic: "setTemperature"
        retain: true
        payload: "{{ states('input_number.target_temp') | int }}"
Why are messages not published ???
When you look in automation and adjust the temp slider, does it show as triggered? Should flash on top of the trigger with the message “Triggered”
I’m not very experienced … If you mean when I move the cursor to raise or lower the temperature, the temperature value appears above the cursor …
Immagine
I mean in Automations, when you look at it in the GUI editor.
As shown in the blog: 2022.3: Select and play media
triggered
payload_template: "{{ states('input_number.target_temp') | int }}"
Thanks, with the gui it worked !!!
- id: '1648737530359'
  alias: Temp slider moved
  description: ''
  - platform: state
  - service: mqtt.publish
      topic: setTemperature
