Hello, I have a set of input numbers that I use to control the range of my thermostat’s high and low temperatures while I’m sleeping. I normally have the high temperature set to 74. I noticed in the middle of the night it was set to 75. I changed it back to 74 and went to sleep. To my surprise when I woke up, it was set to 75 again.
I checked the Logbook and this is what I see:
[Sleep High Temperature] changed to 75.0 °F by Supervisor
5:57:50 AM - 4 hours ago
[Sleep High Temperature] changed to 74.0 °F by Mike
5:57:37 AM - 4 hours ago
Yes. Node-Red is an external system. In a perfect world its changes would be reported as being performed by Node-Red but, generally speaking, external systems are lumped under Supervisor.
You will need to double-check the Node-Red flow to determine the cause of the issue.
