I wonder if it is possible to use 1 option list for different input_selects.
So what I mean is:
e.g. 1 option list:
Q music
Q music Max Hits
Q-music Error
Joe 80-90
VRT Limburg
VRT Radio 1
and I want to use this for different input_select being:
input_select.zender_kitchen
input_select.zender_living
input_select.transmitter_bedroom
input_select.transmitter_bathroom
input_select.zender_dressing
your description of what you want is pretty unclear. do you mean:
do you have many input_select that have the same options and you’re looking to have 1 main input_select control them such that when you select something on your input_select.main, it selects the same thing on all the others? (ie, the selected option is synchronized)
or are you saying that the actual options (the possible choices) on your main input_select changes, and when you change what possible choice you could have on the main one, the possible choices should update on the others? (ie, the set of possible choices is synchronized)
or something else?
if you’re asking about 1, you could do something like this
replace test_dropdown with the name of your main input_select.
create a label, put all the child input_selects that you want controlled by your main one in that label. and change your_label_group in my example to whatever name you choose.
