I have a piece of test code which logs the user selection. however when i attempt to load the input_select with my own options it loads the options into the lsit but when the user chnages the selection this doesnt log.
code snippit:
import hassapi as hass
import asyncio
import bleak
from bleak import BleakScanner, BleakClient
class test(hass.Hass):
async def initialize(self):
await self.listen_state(self.scan_ble, "input_boolean.ble_scan_button", new="on")
await self.listen_state(self.confirm_ble, "input_boolean.confirm_ble_device", new="on")
self.listen_state(self.device_Selection, "input_select.test")
def device_Selection(self, entity, attribute, old, new, kwargs):
selected_option = self.get_state(entity)
self.log(selected_option)
async def scan_ble(self, entity, attribute, old, new, kwargs):
self.options = ["a", "b", "c", "d"]
self.set_state("input_select.test", options=self.options)
self.log("here")
async def confirm_ble(self, entity, attribute, old, new, kwargs):
self.log("there")
log:
2023-03-04 06:02:50.013817 INFO AppDaemon: Reloading Module: /conf/apps/test.py
2023-03-04 06:02:50.022347 INFO AppDaemon: Initializing app test_script using class test from module test
2023-03-04 06:02:54.921163 INFO test_script: Option 2
2023-03-04 06:02:58.298493 INFO test_script: Option 1
2023-03-04 06:03:03.239741 INFO test_script: here
I’m presuming im loading the entity incorrectly but can’t see where i’m going wrong.
EDIT: I should add i can see the values back at the dev tools but it will not detect the change:
input_select.test
testing list
Option 1 options: a, b, c, d
editable: false
friendly_name: testing list
