Input Select Buttons Show State
Hi everyone,
I created an Input Select Helper with 3 options to control the volume of my Sonos System. I created 3 scripts for every volume option. (low, medium, high)
Now I want to have three buttons on my dashboard were I can toggle between these 3 options. I manage to add the buttons and to activate the scripts via an automation.
The only thing I have not yet managed to do is show the status of the switches. Apparently that is only possible when the action is: toggle. In my case the action is: call service
This is my yaml code:
type: horizontal-stack
cards:
  - show_name: false
    show_icon: true
    type: button
    tap_action:
      action: call-service
      service: input_select.select_option
        entity_id:
          - input_select.sonos_volume
        option: Low
    icon: mdi:volume-low
    show_state: false
    hold_action:
      action: none
  - show_name: false
    show_icon: true
    type: button
    tap_action:
        entity_id:
        option: Medium
    icon: mdi:volume-medium
    show_state: true
    hold_action:
      action: none
  - show_name: false
    show_icon: true
    type: button
    tap_action:
        entity_id:
        option: High
    icon: mdi:volume-high
    show_state: true
    hold_action:
      action: none
If it is an limitation of the card, you could think of using a different card like the Mushroom Template Card.
You can template a text to show, or chane icon color based on a Jinja2 template.
An alternative can be using Card-mod to change the card based on some variables.
One thing you could do is create a template binary sensor for each of the three states (high, medium, and low) and add those sensors as the entity for each button. I’m pretty sure this would work with the button cards you are using.
I do something similar with some custom-button-cards (I had other ways in which I wanted to control the style, which is why I’ve used those cards). Here’s an edited version of my cards (superfolous styles, etc have been removed).
cards:
  - type: custom:button-card
    entity: binary_sensor.sonos_den_grouped_to_lounge
    color_type: card
    show_icon: false
    state:
      - value: 'on'
        color: var(--accent-color)
    tap_action:
      service: script.sonos_join_child_to_parent
      service_data:
        parent: media_player.sonos_lounge
        child: media_player.sonos_den
    entity: binary_sensor.sonos_den_grouped_to_den
    color_type: card
    show_icon: false
    state:
      - value: 'on'
    tap_action:
      service_data:
        parent: media_player.sonos_den
Thanks for your help. I finally got it working. The buttons do what they’re supposed to do. There’s still one thing I can’t get done. The color. I want the color of the logo to change to orange when active. Any ideas? This is my code:
cards:
  - show_name: false
    show_icon: true
    type: button
    tap_action:
        entity_id:
        option: Low
    show_state: true
    hold_action:
      action: none
  - show_name: false
    show_icon: true
    type: button
    tap_action:
        entity_id:
        option: Medium
    show_state: true
    hold_action:
      action: none
  - show_name: false
    show_icon: true
    type: button
    tap_action:
        entity_id:
        option: High
    show_state: true
    hold_action:
      action: none
You could use custom-button-card, which I linked to, or you could use card-mod, which Timmuhhh linked to.
I am sorry, I don’t have enough knowledge how to do that.
Can you use my code and past that back in a way that it should work? I like to learn, but I don’t know were to go. :slight_smile:
in case anyone is wondering about implementation, I needed the same function. Now the color changes based on the state of the input_select.
Using a button_card.
            icon: mdi:bullseye
            entity: input_select.area_name
            styles:
              card:
                - background-color: >-
                      if (states['input_select.area_name'].state == 'All')
                        return 'blue';
                      else
                        return 'red';
                - box-shadow: none
            tap_action:
                entity_id:
                  - input_select.area_name
                option: All
            hold_action:
              action: none
Now working on the rest, but wanted to share given I started off based on the code above.
now trying to transger this code to a button template so I can use it for multiple buttons with a short call.
This is the template:
button_area_link:
  color_type: icon
  show_name: true
  show_state: false
  icon: '[[[ return variables.icon ]]]'
  entity: '[[[ return variables.entity ]]]'
  name: '[[[ return variables.name ]]]'
  styles:
    card:
      - width: 100px
      - height: 100px
      - background-color: transparent
      - box-shadow: none
            if (parseFloat(states['input_select.area_name'].state) == 'variables.name' )
              return 'var(--primary-color)';
            else
              return 'var(--ha-card-background)';
    icon:
      - width: 100px
      - height: 100px
    name:
      #Capitalize does not work
      - text-transform: capitalize
  tap_action:
      entity_id:
      option: '[[[ return variables.name ]]]'
  hold_action:
    action: none
This is the call:
            template: button_area_link
            variables:
              icon: mdi:car-multiple
Much shorter in my dashboard file.
Everything seems to work except the color changing, which I assume it is due to this:
I also tried it without the parseFloat (got that from some of my google searches)
 if (states['input_select.area_name'].state == 'variables.name' )
Any idea what’s wrong. The cde I posted earlier works, so it is something with the comparison of the strings, or the retrieval of the variables.name…either way, not sure how to debug it because I can’t use the Developer->Template
Have not checked all code but this is wrong, variables should not be in quotes.
I removed the quotes but still not workng. For completion, this is the code in the main yaml. I am only working the template development on a single button to test. This is the non-template code that works as expected.
            icon: mdi:garage-variant
            show_name: true
            styles:
              card:
                      if (states['input_select.area_name'].state == 'Garage')
                      else
                - box-shadow: none
            tap_action:
                entity_id:
                option: Garage
            hold_action:
              action: none
(not sure why the code above does not have the proper spacing when pasted)
All code seems to work. The template code works as expected except the background color change. I mean when clicked, it changes the input_select variable to the right value, just not the color.
Animation
For whatever reason, I this morning, tried it again, and it worked.
Maybe a refresh/caching issue, although I did clear it for my testing. I’ll take it.
            if (states['input_select.area_name'].state == variables.name)
            else
@Haze did you complete this? Would love to see the final code with the entire button row. I would like to do the same thing, your code would save me a ton of time. thx
Sure. Here is the code for the Filter selection area. You need an input select helper to select using the buttons:
#Filter view
      - type: "custom:layout-card"
        layout_type: "custom:grid-layout"
        layout: !include layouts/layout-live-tile.yaml
        view_layout:
            grid-column-start: 1
            grid-column-end: -1
        cards:
          - type: "custom:button-card"
            template: header_card_no_link
            variables:
            view_layout:
              grid-column-end: -1
            variables:
              icon: mdi:bullseye
            variables:
              icon: mdi:home-floor-1
            variables:
              icon: mdi:home-floor-2
            variables:
              icon: mdi:home-floor-g
            variables:
            variables:
              icon: mdi:pool
            variables:
            variables:
              icon: mdi:parking
            variables:
              icon: mdi:home-group
Then in the conditional section:
#Details View
      - type: custom:state-switch
        states:
          ALL:
            view_layout:
              grid-column-end: -3
            cards:
              - type: markdown
                card_mod:
                  style: |
                    ha-card {
                      background: darkred !important;
                      color: wheat;
                      font-size: 1.5em;
                content: >
                  Select an Area
          HOUSE-F1:
            layout: !include layouts/layout-page-columns.yaml
            view_layout:
              grid-column-end: -1
            cards:
              # [Column] Living Room
                layout:
                  margin: -1
                cards:
                    variables:
                    cards: !include collection/lights-living-room.yaml
You’ll need to modify the formatting to fit your theme with the Button Card Templates and Layouts. Hope this helps gets you going.
This is mine:
button_area_link:
  color_type: icon
  show_name: true
  show_state: false
  icon: "[[[ return variables.icon ]]]"
  entity: "[[[ return variables.entity ]]]"
  name: "[[[ return variables.name ]]]"
  styles:
    card:
      - width: 100px
      - height: 100px
      - box-shadow: none
            if (states[variables.entity].state == variables.name)
            else
    icon:
      - width: 100px
      - height: 100px
    name:
  tap_action:
      entity_id:
        - "[[[ return variables.entity ]]]"
      option: "[[[ return variables.name ]]]"
  hold_action:
    action: none
button_room_link:
  styles:
    card:
      - width: 100px
      - height: 75px
      - font-size: 0.75em
      - font-weight: 400
    icon:
      - height: 50px
Here is the final result:
Filter Views
