I changed from the rc version to latest in docker my input_selects have changed to input_select_2, what’s the best way to delete them and get back to input_select
you can just rename them it it complains that it already exist
then try and delete the existing ones
if you can’t delete cause it complains the intergration needs to be removed
just # out them in the config reboot, remove, un# and reboot
simple
I’ll try that, thanks
Getting back to this, i had no luck deleting commenting out and re-adding the input_select code and ended up just renaming the input_selects and re-doing any code that uses them
