Hello everyone. Could you help me with this automation. I want that when changing an input select the home theater changes to the same place. I’m doing something wrong because I can’t get the home theater to match the input select
I think maybe the automation is wrong. Thank you
- alias: bdv_n9200w_change_source
description: "Cambia media con Broadlink cuando se cambia input_select.home en home assistant"
- platform: state
entity_id: input_select.home
condition:
- "{{ now() - state_attr('automation.bdv_n9200w_input_select', 'last_triggered') >= timedelta(seconds=4) }}"
variables:
repeats: >
{% set sources = ["Bluetooth","Audio","DB DVD","USB","FM Present","HDMI 1","HDMI 2","TV","SCR M"] %}
{% set old_pos = sources.index(trigger.from_state.state) | int(0) %}
{% set new_pos = sources.index(trigger.to_state.state) | int(0) %}
{% if new_pos >= old_pos %}
{{ new_pos - old_pos }}
{% else %}
{{ (sources|length - old_pos) + new_pos }}
{% endif %}
repeat:
count: "{{repeats}}"
sequence:
- service: script.bdv_n9200w_source
Script
bdv_n9200w_source:
sequence:
- service: remote.send_command
entity_id: remote.broadlink_rm3_comedor
command: 'b64:JgDuAFESKRIVExQTKBMUEygTKBMUExUSFRIVEygSFRMoEygAApxREygSFRMTFCgTFBMnFCgTExQUExQTFBQnExQUJxQnAAKdUBQnExQUExQnFBMUJxQnFBQTFBMUExQUJxQTFCcUJwACpk8UJxQUExQTKBMUEygTKBMUExQUExQTFCcUFBMoEygAAqVQEygTFBMUFCcUExQnFCcUExQUExQTFBMoExQUJxQnAAKlUBQnFBMUExQnFBQTKBMoExQTFBMUFBMUJxQTFCcUJwACpk8UKBMUExQTKBMUFCcUJxMUFBMUFBMUEygTFBMoEygADQUAAAAAAAAAAAAA'
- delay: '00:00:01'
