Here is my current setup. 3 radiators connected to Sonoff S20’s flashed with tasmota. I then have 3 scripts and an Hours input slider to put the radiator on for a timer for a dynamic number of hours. Is there anyway to combine the three scripts to an input select? how do i do that?
Config
# Input slider (Hours)
input_number:
hours:
icon: mdi:clock
min: 0
max: 12
step: 1
#Switches
#Bedroom Radiator
- platform: mqtt
command_topic: "cmnd/home/sonoff01/power"
state_topic: "stat/home/sonoff01/POWER"
gos: 1
payload_on: "ON"
payload_off: "OFF"
retain: true
#Man Cave Radiator
- platform: mqtt
command_topic: "cmnd/home/sonoff03/power"
state_topic: "stat/home/sonoff03/POWER"
gos: 1
payload_on: "ON"
payload_off: "OFF"
retain: true
#Living Room Radiator
- platform: mqtt
command_topic: "cmnd/home/sonoff04/power"
state_topic: "stat/home/sonoff04/POWER"
gos: 1
payload_on: "ON"
payload_off: "OFF"
retain: true
#Scripts
script1:
alias: LR Radiator Timer
sequence:
- service: switch.turn_on
entity_id: switch.sonoff04
- delay: '{{ states.input_number.hours.state | int }}:00'
- service: switch.turn_off
script2:
alias: MC Radiator Timer
sequence:
entity_id: switch.sonoff03
script9:
alias: Bedroom Radiator Timer
sequence:
entity_id: switch.sonoff01
#Automations to stop scripts
#LR timer
- id: 1x
alias: Turns off LR timer
platform: state
to: 'off'
service: homeassistant.turn_off
entity_id: script.script1
#MC timer
- id: 1x
alias: Turns off MC timer
platform: state
to: 'off'
entity_id: script.script2
#Bedroom timer
- id: 111x
alias: Turns off Bedroom timer
platform: state
to: 'off'
entity_id: script.script9
