Thanks, I will try that out, but I am a bit concerned about triggering something every minute to check stuff that will only apply once in a while and only between certain hours of the night.
Yeah, I know what you mean. There is another way I do this and I’ll check tonight at home but I use about 50 automations that are time triggers and no difference in performance. I’ll see if I can dig up the other method that I know works too.
I have tried and it works with >=, but not if I use ==, which is strange. The former is fine, but I need to reset a boolean switch then in order not to trigger the automation continously.
Yes, that could be worth a try. However, it worked nicely with >=, which also allows trigger every 5 minutes or less (as I going to have my input_select in steps of 30 minutes.
