Is there a restriction in how input_selects work in scenes combined with an input_boolean?
The combination of a input_select and a input_bolean does not work in a scene.
my usb automation/script dont trigger anymore.
When i delete the input_boolean my usb works again…
The boolean does work
i have the same script for off with the right states, same problem!
- id: '1699019809471'
entities:
input_select.usblamp:
options:
- uit
- aan
- flame
- wit
- play
- dim
- snel
- rood
- blauw
- groen
- paars
- roze
- oranje
- grijs
editable: true
icon: mdi:coach-lamp
friendly_name: usblamp
state: flame
input_boolean.kaarsen:
editable: true
icon: mdi:candle
friendly_name: kaarsen
state: 'on'
metadata:
entity_only: true
entity_only: true
Context
Use a rpi4b, with latest beta hass in docker
It concerns two ir lamps. Both are served by a broadlink script at the end that does the trick, sending the ir command.
Ir device kaarsen, has only a on or off, so thats easy, It uses an input boolean for that and a automation to call the default broadlink script.
The other ir lamp is much complexer with lots of colors that has to be reset and count. This also works great.
Combination of these two entities in a scene to combine them for example scene evening did work with 6 other normal rfx lamps in the scene till i combined a boolean and a input select in the scene.
When i execute the scene manually it is not working, when putting these two devices in separate scenes and exec them manually its working. So strange
script.1697882284549 is the generic broadlink script that serves them both.
The usblamp also contains some “trials” toe play with speach, not interesting for this part
and it turns on the receiver by turning on a walloutlet which also enables the ir receiver , i have to reset the ir integration for that. I can disable the speech and all the startup receiever stuff to make it more easier…
alias: usblamp
description: >-
moet mode parallel, anders kun je met een script niet en de usb_spraak
verwerken en zichzelf nogmaals starten voor de afhandeling via de usb_knop
- platform: state
entity_id:
- input_select.usblamp
- platform: conversation
command:
- Zet usblampxx op {color}
condition: []
- choose:
- conditions:
- condition: trigger
id:
- usb_knop
- condition: state
entity_id: switch.ac_0e672c2_13
state: "off"
sequence:
data: {}
entity_id: input_boolean.ir_receiver
- delay:
hours: 0
minutes: 0
seconds: 60
milliseconds: 0
enabled: true
- service: homeassistant.reload_config_entry
entry_id: 6e385ed7335c6a8d050336b57684d290
enabled: true
- delay:
hours: 0
minutes: 0
seconds: 60
milliseconds: 0
enabled: true
- service: script.turn_on
variables:
keuze: "{{ keuze }}"
entity_id: script.1697882284549
- conditions:
id:
- usb_knop
- condition: state
state: "on"
sequence:
variables:
- conditions:
id:
- usb_spraak
sequence:
- service: input_select.select_option
option: "{{ trigger.slots.color }}"
entity_id: input_select.usblamp
enabled: true
- service: tts.google_translate_say
entity_id: media_player.chromecast_huiskamer_nest
message: De usblampxx krijgt de waarde {{ trigger.slots.color }}
cache: true
language: nl
enabled: true
variables:
keuze: "{{ states('input_select.usblamp') }}"
mode: parallel
max: 2
alias: kaarsen
description: zet kaarsen aan of uit is broadlinktechnologie
- platform: state
entity_id:
- input_boolean.kaarsen
to: "on"
- platform: state
entity_id:
to: "off"
condition: []
variables:
keuze: "{{trigger.id}}"
Hi pedolsky, I found it!
There wasn’t an error in my scripts…
I made a script that did the same as a scene woukd do, and the same problem, one ir lamp does not go on or off. And every entitie was is the correct end-state.
Problem is the speed of the handling in the scene
the on/off commands come to quick for the broadlink ir devices…
After making a delay in my script (1 second) it worked fine
Is there a way to create a delay between entities in a scene
Otherwise i make my own on/off script/scene
