hassio 0.62.1 need help with input select. I have tried everything from leaving out the initial to including “default” as the initial to setting initial to one of the two bottom themes.
2018-02-01 16:00:24 ERROR (MainThread) [homeassistant.config] Invalid config for [input_select]: initial state “default” is not part of the options: -default -solarized -darkcyan -midnight -darkorange for dictionary value @ data[‘input_select’][‘hass_themes’]. Got OrderedDict([(‘name’, ‘Theme Names’), (‘options’, ‘-default -solarized -darkcyan -midnight -darkorange’), (‘initial’, ‘default’), (‘icon’, ‘mdi:theme-light-dark’)]). (See /config/configuration.yaml, line 249). Please check the docs at https://home-assistant.io/components/input_select/
here is my input_select element.
hass_themes:
options:
-default
-solarized
-darkcyan
-midnight
-darkorange
initial: default
icon: mdi:theme-light-dark
any help would be appreciated.
Bud
