Hi all,
would it be possible to have a service that allows adding and removing an option to an input_select entity? Currently there’s only a service to set options which will overwrite the existing ones.
background:
- I have set up a folder watcher
- automation detects new files in that folder
- automation shall add new filename to selection
- template sensor creates an url which points to the new file
- a custom-ui state card displays that link clickable
So, in the frontend I can choose a file from dropdown and below appears the url to access the file
I tried to workaround, but this seems not to work: (any hint appreciated)
- service: input_select.set_options data_template: entity_id: input_select.datasheet options: >- {{ states.input_select.datasheet.attributes.options|replace("]", ", '" + trigger.event.data.file + "']") }}
