i recognized some (not all) of my input_selects are unavailable since a few days. Also a restart does not help. It also makes no difference if i set a initial value or not. Any ideas how to fix that?
What changed a few days ago?
⦠And how/where do you define them ?
Please post a representative sample
My guess is that, several days ago, you edited the configuration file and accidentally introduced a new, empty input_select:
section (located after the original, non-empty, input_select:
section).
Sorry again, you are right (it was late yesterday ). That would help. Here is my code:
input_select:
temperature_states:
name: AuĆentemperatur in fünf Temperaturstufen diskretisiert
options:
- "0"
- "1"
- "2"
- "3"
- "4"
- "5"
icon: mdi:oil-temperature
alarm_states:
name: Alarm Status bzgl. Fenster offen und Licht an
options:
- "0"
- "1"
- "2"
- "3"
icon: mdi:sign-caution
mercedesme_choosen_day:
name: Auswahl des Tages zur Anpassung der Aktivierungszeit für die Standheizung
options:
- "Montag"
- "Dienstag"
- "Mittwoch"
- "Donnerstag"
- "Freitag"
- "Samstag"
- "Sonntag"
initial: "Montag"
input_select:
alexa_message_target:
name: Type Of Broadcast
options:
- "media_player.echo_alexa"
- "media_player.echo_computer"
- "media_player.echo_echo"
- "group.alexa_all"
initial: "media_player.echo_alexa"
icon: mdi:speaker-wireless
Sorry that i have not explained this. I did a lot of work the last days (no work and exit lock due to corona at the moment). For this reason i could not define what was the change which created the problem. Thatās a part of my problem
But you are awesome. Yout expectation was correct. I introduced a second āinput_select:ā - line (as you see above). After a test it is now again working as intended.
Thank you very much
That was either a āhellovanā insightful guess, you have done some very weird stress testing or you have a very good memory as someone has done this before.
Any which way, kudos to you
Iāll have to try to do that as I donāt see how it would even pass a config check
Thatās exactly what surprised me the most. But it did pass the config check.
I did a quick check of how my system is configured and I have 43 packages (so a potential to have 43 separate and valid instances of āinput_select:ā but I actually only have 5 of them).
So I can see why putting a check for that would be a āa little more involvedā for the config checker.
Ah well, itās one those to be filed away and try to ensure it doesnāt happen again.
Good luck with your config updates.
