Input_select with value and label?
Hello I command my Heaters mode with an Input_select like this
Capture%20du%202018-05-12%2023-26-41
when the select is changed, an automation trigger a shell command wich send a radio command to the heater.
This radio order is litterally, the R12 or R11 or R10, which is decoded by the receiver.
I would like to have some labels insted of R10… how can I still pass R10, R11 or R12 to the shell but have some frindly user labels in my input_select?
here is my conf:
input_select:
  radia_cuisine:
    options:
      - "R12"
      - "R11"
      - "R10"
    icon: mdi:target
shell_command:
  set_radia_cuisine: '/usr/bin/python3 /home/homeassistant/testSerial.py {{ states.input_select.radia_cuisine.state }}'
#automation
- alias: Set Thermostat Mode
        platform: state
        entity_id: input_select.radia_cuisine
    service: shell_command.set_radia_cuisine
input_select:
  radia_cuisine:
    options:
      - Hot like lava
      - Warm like toast
      - Cold like ex wife
    icon: mdi:target
shell_command:
  set_radia_cuisine: /usr/bin/python3 /home/homeassistant/testSerial.py "{{ command  }}"
#automation
    platform: state
    data_template:
      command: >
        {% if is_state('input_select.radia_cuisine' , 'Hot like lava') %} R12
        {% elif is_state('input_select.radia_cuisine' , 'Warm like toast') %} R11
        {% elif is_state('input_select.radia_cuisine' , 'Cold like ex wife') %} R10
        {% else %} R00 {% endif %}
Thx it works !
Hi there,
I did something along these lines. Have a look here:
Hello @pkozul ,
Files lookes like no more available:
https://raw.githubusercontent.com/pkozul/ha-input-select/master/custom_components/input_select.py https://raw.githubusercontent.com/pkozul/ha-input-select/master/packages/radio.yaml
Have you hot new linke or a better solution?
Feature request related to input_select and adding labels and values that would make the solution to your problem so much more elegant: Input_select enhancement. Support mapping - #18 by sytone
