Input slider widget with only integer
How can be removed the decimal value at input slider widget?
I’d like to use it for input hours and minutes, so the decimal is not necessary (and weird a little bit).
Have you tried precision: 0 or commented it out in the global parameters of the dashboard?
global_parameters:
    use_comma: 0
#    precision: 0
Thank you very much!
The precision setup was 1.
