Input Slider with transition?
Is it possible to add a transition to an input slider to slow it down to whatever number (seconds) I add?
I’ve tried a couple of ways like this
office_light_slider_25:
  sequence:
    - service: input_slider.select_value
      entity_id: input_slider.office_light_brightness
        value: 25
        transition: 5
  sequence:
        value: 25
          transition: 5
None of them worked, but it didn’t report any errors either.
No, this is not possible with an input_slider since a input_slider does not have/use the transition attribute.
I think you are looking for the light component to do what you want:
      - service: light.turn_on
          entity_id: light.office_light
          brightness: 25
          transition: 5
You can also add Input Sliders for the brightness and the transition times. The next example shows how you can call the same service I used above, but using the values of input slider instead of a static value:
        data_template:
          brightness: '{{ input_slider.office_light_brightness }}'
          transition: '{{ input_slider.office_light_transition }}'
Thanks a lot, I’ll play around with this later :slight_smile:
