I’m trying to get a slider fixed underneath my player selection. I got this out of Bob_NL’s thread, but can’t find any solution to get this sorted out.
I might be overseeing something…
When i put this in my configuration.yaml Home assistant is happy
# Radio Button Select
input_select:
radio_station:
name: 'Welke zender wil je luisteren:'
options:
- Radio 538
- Radio 538 Ibiza
- SLAM!
- SLAM! The Boom Room
- SLAM! Hardstyle
- SLAM! juize
- Q-Music
- Q-Music Christmas Station
- FunX Slow Jamz
- FunX Reggae
- 3FM
- 100% NL
- Veronica
- Sky Radio
- Sky Radio Christmas
- Arrow Classic Rock
- Classic FM
- BNR Nieuwsradio
- Radio Art - Sleep
- Ambi Nature Radio
- Calm Radio - Sleep
- Dinamo.FM Sleep
chromecast_radio:
name: 'Op welk apparaat wil je het afspelen:'
options:
- Woonkamer
- Overloop
- Allemaal
initial: Allemaal
icon: mdi:speaker-wireless
When i try to add the slider it get’s angry:
input_select:
radio_station:
options:
- Radio 538
- Radio 538 Ibiza
- SLAM!
- SLAM! Hardstyle
- SLAM! juize
- Q-Music
- FunX Slow Jamz
- FunX Reggae
- 3FM
- 100% NL
- Veronica
- Sky Radio
- Classic FM
- BNR Nieuwsradio
- Radio Art - Sleep
- Ambi Nature Radio
- Dinamo.FM Sleep
chromecast_radio:
options:
- Woonkamer
- Overloop
- Allemaal
initial: Allemaal
input_slider:
volume_radio:
icon: mdi:volume-high
min: 0
max: 1
step: 0.05
I also tried splitting things apart by creating a “inputs.yaml” file and in configuration.yaml added the input: !include inputs.yaml but that messed up things way more cause home assistant couldn’t find the integration of inputs
Actually, the question is why do you think it’s called input_slider? There’s no such integration (there used to be one until its name was changed to input_number many, many versions ago).
A secondary question is who is Bob_NL (or is it Bob_N) and how old is the post he wrote?
You can if you want. If you put it in input_numbers.yaml like you could/would with automations.yaml etc then just be sure to remove the opening input_number: header, so it would just be:
that said, it depends how you include that file… if its in a package, no change to the original is required, if its linked from your configuration.yaml like:
input_number: !include input_numbers.yaml
then you remove the input_number: header confused yet?
Out of curiosity, why didn’t you mark Ashcroft’s post as the Solution? It was the very first post that suggested you use input_number instead of input_slider. That’s the only change required to correct the problem.
I think, probably, because @ashscott assumed the OP would actually ‘read’ responses
Whereas @sparkydave just handed it to him on a sugar coated spoon ???
Ohh my… Excuse me… Didn’t know it was that important.
I like to be spoonfed, don’t you?. The difference is do you learn something from it… Yeah i do . Because i read all comments. Just didn’t expect it to be so important to mark the first reaction which solves it to be the solution.
No, I like to know what I did wrong, where I should go to read up to correct it, and by implication be able to resolve similar issues in future without moaning from the backseat. @ashscott 's response was perfect for that.
You didn’t even check that there was an integration for input_slider, you just attacked the first guy that told you that there wasn’t
It’s the custom of this community to attribute the Solution to the first contributor who identifies the source of the problem and offers a solution. However, you are, of course, free to select another post and mark it as Solution, especially if it is a more complete solution.
In this case, the source of the problem was that you had used a deprecated entity domain (input_slider) and ashcroft correctly identified that it should be replaced by input_number. That’s the solution right there. However, if you feel there’s a need to see the solution used in an example, that’s your choice.
Edited in a small warning notice to that Bob_NL post about the rename to input_number.
It’s always recommended to check the documentation when having problems like this, since great effort is made to ensure the documentation is kept up to date with the latest release. That’s almost never going to be the case with old forum posts from several years ago.
Also, you can now add and edit this stuff directly in the UI at Configuration -> Helpers.
Just a quick note on this particular example. The original thread does actually explain the switch from input_slider to input_number right here. It was actually brought up quite a few times by others who skipped over the change and subsequently ran into trouble.
Hi there,
Bob_NL here. Indeed, the component changed since I created the topic. Thanks for adding the warning notice @SeanM! I can’t change the post anymore, otherwise I had changed the config on several points in the meantime.
No problem. I never understood why Discourse limits people from editing their own topics after a certain point. If you or anyone else needs something edited in the future, always feel free to PM or tag me
