daenny
(Daniel Claes)
January 1, 2017, 6:10pm
1
It would be great to have a easy input_time component for simple automation.
Many people have done it in various forms in the topic here:
That can be due to the copy paste on the board. The following never shows any errors
sudo -u homeassistant /srv/homeassistant/homeassistant_venv/bin/hass --script check_config
Testing configuration at /home/homeassistant/.homeassistant
But I think it would be great to have a simple component which just shows the time and on click opens a new card (similar to the climate component) to set the time.
The value could then be used for the automation rules.
I am using the following config to generate my time based automation:
input_slider:
auto_heat_hour:
icon: mdi:timer
initial: 6
min: 0
max: 23
step: 1
auto_heat_min:
icon: mdi:timer
initial: 5
min: 0
max: 55
step: 5
auto_heat_duration:
icon: mdi:timer
initial: 50
min: 1
max: 120
step: 5
- template:
auto_heat_time:
friendly_name: 'Heating start'
value_template: '{{ "%0.02d:%0.02d" | format(states("input_slider.auto_heat_hour") | int, states("input_slider.auto_heat_min") | int) }}'
auto_heat_duration:
friendly_name: 'Heating duration'
value_template: '{{ "%2d minutes" | format(states("input_slider.auto_heat_duration") | int) }}'
automation:
- alias: "auto_heat_on enabled"
platform: state
entity_id: input_slider.auto_heat_hour, input_slider.auto_heat_min, input_slider.auto_heat_duration
- service: homeassistant.turn_on
entity_id:
- automation.auto_heat_on
entity_id:
- automation.auto_heat_off
- alias: 'auto_heat_on'
initial_state: True
- platform: time
minutes: '/5'
seconds: 14
condition:
- condition: template
value_template: '{{ (now().strftime("%s") | int | timestamp_custom("%H:%M")) == states.sensor.auto_heat_time.state }}'
- service: climate.set_temperature
entity_id: climate.ethermostaat
temperature: 19
- alias: 'auto_heat_off'
initial_state: True
- platform: time
minutes: '/5'
seconds: 14
condition:
value_template: '{{ ((now().strftime("%s") | int - (states("input_slider.auto_heat_duration") | int) * 60) | timestamp_custom("%H:%M")) == states.sensor.auto_heat_time.state }}'
- service: climate.set_away_mode
away_mode: True
It shows as:
So what I would like to have is basically an input which has the value of the time accessible in timestamp format and on click you can adjust the values of the hour and minutes with the sliders. that would simplify the rules quite a bit.
turboc
(Chip Cox)
January 1, 2017, 10:30pm
2
Yes yes please. and make a dashboard widget for it too when you do it.
daenny:
alias: “auto_heat_on enabled”
platform: state
entity_id:
entity_id:
alias: ‘auto_heat_on’
initial_state: True
platform: time
minutes: ‘/5’
seconds: 14
condition:
condition: template
value_template: ‘{{ (now().strftime(“%s”) | int | timestamp_custom(“%H:%M”)) == states.sensor.auto_heat_time.state }}’
temperature: 19
alias: ‘auto_heat_off’
initial_state: True
platform: time
minutes: ‘/5’
seconds: 14
condition:
condition: template
value_template: ‘{{ ((now().strftime(“%s”) | int - (states(“input_slider.auto_heat_duration”) | int) * 60) | timestamp_custom(“%H:%M”)) == states.sensor.auto_heat_time.state }}’
away_mode: True
Can u just post all groups and stuff for this awesome timer??
daenny
(Daniel Claes)
January 7, 2017, 12:54pm
5
The code above is only missing the time sensor component and a group which contains all those items. So it is rather complete, I think.
So I guess it’s in 0.55 now?
I just don’t know how to actually use it. If anyone can help…?
elRadix
(elRadix)
October 15, 2017, 10:51am
7
I’m also interested how this input datetime can be used with the above climate example
Can anyone help me?
I have this automation:
- alias: 'Ochtend Verwarming'
platform: state
entity_id: input_number.morningheatinghour, input_number.morningheating_min, input_number.morningheatingduration
entity_id:
- automation.morningheating_on
entity_id:
- automation.morningheating_off
- alias: 'morningheating_on'
initial_state: True
- platform: time
minutes: '/5'
seconds: 14
condition:
condition: and
conditions:
value_template: '{{ (now().strftime("%s") | int | timestamp_custom("%H:%M")) == states.sensor.morningheating_time.state }}'
- condition: state
entity_id: input_boolean.morningheatingstatus
state: 'on'
service: scene.turn_on
entity_id: scene.Ochtend_Prog_aan
- alias: 'morningheating_off'
initial_state: True
- platform: time
minutes: '/5'
seconds: 14
condition:
condition: and
conditions:
value_template: '{{ ((now().strftime("%s") | int - (states("input_number.morningheatingduration") | int) * 60) | timestamp_custom("%H:%M")) == states.sensor.morningheating_time.state }}'
- condition: state
state: 'on'
entity_id: scene.Ochtend_Prog_uit
Second automation doesn’t trigger.
How to solve?
daenny
(Daniel Claes)
October 27, 2017, 2:52pm
9
The conditions are only checked every 5 minutes. What are you input values?
If your set times are not a multiple of 5 the trigger will never match. You could try to set the minutes to '/1'
in the trigger.
Yes! That was it! I had 5min steps but starting at 1 min, so it was always 1 or 6 or 11 etc.
Thanks!
elRadix
(elRadix)
October 27, 2017, 4:53pm
11
@daenny can you share the full corrected config please.
thanks
rabittn
(Ryan)
October 27, 2017, 6:07pm
12
I use a template trigger for this instead of checking once a minute or every five minutes.
value_template: '{{ states.sensor.time.state == states.sensor.chicken_door_time.state }}'
