im building my first sensor with esp home. ive got everything running and the sensor is showing realistic values, its just not calibrated. im following this tutorial https://peyanski.com/diy-ph-sensor-for-home-assistant/
its a ph sensor and the probe I got from aliexpress give an analog signal from 0-5V. the tutorial has a potentiometer build in the circuit presumable to translate the 0-5V rage to the range that the d1 mini can read.
i read that i can use either a voltage divider or a potentiometer to do this, however i cant figure out what the input range of the d1 mini is. its either 0-3.3V or 0-1V but i havent fully understood calibration process.
can someone shed some light on this ADC process?
