My water service company can now provide daily meter reading in xls or csv format and I would like to insert these values in a “Utility Meter” module once a month.
Is there a way to do this?
Edit: is it possible to perform insert commands in influx DB?
One way of achieving this is, to have a script re-write the csv file to a new file line by line in chronological order. The sensor will then pick up the values that you can then parse in home assistant to what you want with template sensors.
I’m not sure if the utility meter will work with this because it usually is used with regularly updated sensors and takes time stamps of updates into account. But you can always try and see if it gives what you need.
Exactly. That’s why I suggested re-writing the csv file to a new file. That new file should be monitored by the sensor and that will pick up the last line after each write.
got you point … but I dont think I can enter the date.
For example if I have a list of daily reading for August, how can I add them with the correct date?
I’m not so sure about what i will propose, but there’s a slight chance i’m right:
Influx DB draws data from maria DB or another database right?
Can’t you manually insert data on the source database with PHPMyAdmin?
There’s an addon that lets you browse and edit mariaDB.
my electricity sensor write directly into the influxdb … will need to find some commands how to insert data manually into influxdb … will try to follow this when I have some time
