Loader23
(Loader23)
November 24, 2019, 10:35am
1
I have this automation:
value_template: >
{{ states('sensor.hz_temp')|float < states('input_number.starttemp')|float }}
- platform: time
at: 05:15:01
- platform: time
at: 08:15:01
condition:
condition: and
conditions:
- condition: template
value_template: >
- condition: or
conditions:
- condition: and
conditions:
- condition: state
entity_id: binary_sensor.workday_sensor
state: 'on'
- condition: time
after: 05:15:00
before: '22:15:00'
- condition: and
conditions:
- condition: state
state: 'off'
- condition: time
after: 08:15:00
before: '22:15:00'
I want to replace the time trigger and conditions with input Datetime so I can control it in the frontend.
Researches here brought me to this:
value_template: >
value_template: "{{ states('sensor.time') == (state_attr('input_datetime.mofr', 'timestamp') | int | timestamp_custom('%H:%M', True)) }}"
value_template: "{{ states('sensor.time') == (state_attr('input_datetime.saso', 'timestamp') | int | timestamp_custom('%H:%M', True)) }}"
condition:
condition: and
conditions:
value_template: >
- condition: or
conditions:
- condition: and
conditions:
- condition: state
state: 'on'
value_template: "{{ states('sensor.time') > (state_attr('input_datetime.mofr', 'timestamp') | int | timestamp_custom('%H:%M:%S', true)) }}"
value_template: "{{ states('sensor.time') < (state_attr('input_datetime.ende', 'timestamp') | int | timestamp_custom('%H:%M:%S', true)) }}"
- condition: and
conditions:
- condition: state
state: 'off'
value_template: "{{ states('sensor.time') > (state_attr('input_datetime.saso', 'timestamp') | int | timestamp_custom('%H:%M:%S', true)) }}"
Now I have two Questions:
Does that work like the code before or did I miss something?
How can I add 1 second to the trigger template so that I can be sure the conditions are met like it was in the code before?
Mutt
(Muttley)
November 24, 2019, 11:10am
2
No, the sensor.time only updates every minute.
If you want second interval update you have to check every second (which is possible) but this spams everything and is particularly high in its consumption of resources. Not recommended in any circumstances.
But if you want to try set a trigger on a time_pattern: seconds: ā*1ā
Your time pattern matching is also a bit processor intensive and could be simplified (Iām working from a phone so canāt comment on the functionality of the whole code)
Instead of : Try : -
Replace with
"{{ states('sensor.time') [0:5] == states('input_datetime.saso') }}"``
Also, states. Ie states followed by a full stop is not very fault tolerant so states() is preferred and more resilient.
Loader23
(Loader23)
November 24, 2019, 11:34am
3
Didnāt thought that this would be so complicate to achieve.^^
Why is the time pattern more processor intensive? I have that right from the docs
And what do you mean with followed by a full stop?
Isnāt there another way to add this one second, maybe implementing a delay or something?
Mutt
(Muttley)
November 24, 2019, 11:36am
4
states.thing vs states(āthingā) you see the ā.ā between states and thing ?
Mutt
(Muttley)
November 24, 2019, 11:37am
5
Look at the number of operations you are asking it to perform rather than the alternate
Mutt
(Muttley)
November 24, 2019, 11:39am
6
Yes thatās always an alternative and preferred but thatās not what you asked.
The template (youād need two) would have to do some splitting operations but that is doable
Loader23
(Loader23)
November 24, 2019, 12:27pm
7
So is this a general advice? Because I do not see any states.thing in my code?
Just out of curiosity and because I just found it, what would this do? (int +1):
"{{ states('sensor.time') == (state_attr('input_datetime.mofr', 'timestamp') | int +1 | timestamp_custom('%H:%M', True)) }}"
123
(Taras)
November 24, 2019, 12:37pm
8
Do these two input_datetimes, mofr
and ende
, have both date and time or just the time?
123
(Taras)
November 24, 2019, 12:54pm
10
Then I donāt understand why you are taking the input_datetimeās timestamp and then converting it into UTC time (using the True
option in timestamp_custom
sensor.time
reports the local time, not UTC time. Unless local time is equal to UTC time where you live, comparing the two values will not work the way you want.
I think what you want is simply this:
"{{ states('sensor.time') == states('input_datetime.mofr')[:5] }}"
EDIT
Thereās no need to reduce the clock tick to a 1-second resolution. Simply adjust the test in your conditions:
value_template: "{{ states('sensor.time') >= states('input_datetime.mofr)[:5] }}"
value_template: "{{ states('sensor.time') <= states('input_datetime.ende')[:5] }}"
Loader23
(Loader23)
November 24, 2019, 1:07pm
11
I have done it that way because thats what I have found here and the docs and because I do not know it better
I just saw the >= in the code.^^ Thanks alot, both of you, I will test it but it looks good
-edit-
Working as expected. Thank you so much!
Mutt
(Muttley)
November 24, 2019, 1:39pm
12
Yo are correct, dunno why I said that maybe I just misread it on my phone
Mutt
(Muttley)
November 24, 2019, 2:14pm
13
Loader23:
I was just showing you a template for the trigger, conditions need to be considered differently
