Insert an option to choose device or entities filter defaults
Maybe I’m missing it but when I go to an integration and click on the entities it always shows the disabled ones…
Example…
From the “Settings Menu” I’ll choose “Devices & Services” and it will show cards with all my integrations
I’ll click on the “183 Entities” on the MQTT card and all my entities show up including disabled. I can change the filter to not see them but if I go out and come back they are there again by default.
I disable, hide or remove what I don’t need and would only like to see it when I need to not by default. Would be great if we could choose the filters default settings… I’ve looked and can’t seem to find anything on it.
The “Entities” section is designed to show all entities, ( it not only has integration’s but everything like scripts, & non-existent entities that the system still needs to keep a record of like deleted scripts ). when you go to this menu via an integration, it filters for just that integration’s entities.
It doesn’t make much sense to filter it anymore, because newbie’s already have trouble conceptualising this.
What might be a better idea is having predefined filters (that the user defines) that can be applied to all entities (not just A single integration). So if a newbie wanted to do what you’re suggesting, they can but more advanced users can use it to create predefined group’s of entities (they’re interested in) from all different integration’s, but this list would get very large if it was done for every integration.
Anyway, that’s my two cent’s worth.
Sounds like a great way to do it. I’d just like to have a bit more control over what I do and don’t have presented. We all work a little differently to accomplish the same thing and for me it’s annoying to have something I don’t need to see and filter through keep coming back.
