Instability after Supervisor update
Just came back from a few days away and there was a Supervisor update which I was silly and pressed update. Normally I would see what the update includes to minimise risk of problems like this.
My Home Assistant which is installed I my Unraid server as a VM and generally works great.
So now, occasionally the ESP modes drop out randomly. All of them , not just some.
It must be something updated that was installed. The Restarting sometime fixed it but it still goes loses them periodically.
I have done a full backup recover but it’s still happening. Strange and the Supervisor update has not gone?
I do have some logs from the time of then not working below:
Source: runner.py:189
First occurred: 01:38:34 (15 occurrences)
Last logged: 03:13:10
Can't connect to ESPHome API for esphome-web-23d778 @ 192.168.1.11: Error connecting to [AddrInfo(family=<AddressFamily.AF_INET: 2>, type=<SocketKind.SOCK_STREAM: 1>, proto=6, sockaddr=IPv4Sockaddr(address='192.168.1.11', port=6053))]: [Errno 113] Connect call failed ('192.168.1.11', 6053) (SocketAPIError)
Can't connect to ESPHome API for atlas-water-sensors @ 192.168.1.18: atlas-water-sensors @ 192.168.1.18: The connection dropped immediately after encrypted hello; Try enabling encryption on the device or turning off encryption on the client (Home Assistant 2024.9.1). (HandshakeAPIError)
Can't connect to ESPHome API for atlas-water-sensors @ 192.168.1.18: Timeout waiting for HelloResponse, ConnectResponse after 30.0s (TimeoutAPIError)
Can't connect to ESPHome API for atlas-water-sensors @ 192.168.1.18: Error connecting to [AddrInfo(family=<AddressFamily.AF_INET: 2>, type=<SocketKind.SOCK_STREAM: 1>, proto=6, sockaddr=IPv4Sockaddr(address='192.168.1.18', port=6053))]: [Errno 113] Connect call failed ('192.168.1.18', 6053) (SocketAPIError)
Can't connect to ESPHome API for atlas-water-sensors @ 192.168.1.18: Timeout while connecting to [AddrInfo(family=<AddressFamily.AF_INET: 2>, type=<SocketKind.SOCK_STREAM: 1>, proto=6, sockaddr=IPv4Sockaddr(address='192.168.1.18', port=6053))] (TimeoutAPIError)
Sorry, not great at importing can you read that on a desktop.
The supervisor updates automatically whether you are home or away and whether you press update or not.
