Instalation on VirtualBox borked
So yesterday and today I’ve been attempting to get HomeAssistant up and running. Well following both a turial i found on youtube by TheHookUp and the instructions on the HomeAssistant install pages i wind up with the same issue. VM spins up fine goto the web page to do onboarding and I’m left at the preparing home assistant drop page. looking into the blue button and logs reveils that it keeps timing out trying to download a supervisor docker update. thru some tomfullery i got it to downgradeish but then I’m stuck without supervisor and a partial HomeAssistant install. Im wondering if anyone has Been able to get the latest version running on VM?
Are you doing this on Windows or Linux?
Are you downloading haos_ova-6.5.vdi.zip?
I would go here to download and choose the VDI:
https://www.home-assistant.io/installation/linux/
Are you bridging the ethernet to the host machine?
I have the latest VM running on Linux on a dedicated server. I run ubuntu 20.04. Here is my info:
System Health
Version core-2021.10.6
Installation Type Home Assistant OS
Development false
Supervisor true
Docker true
User root
Virtual Environment false
Python Version 3.9.7
Operating System Family Linux
Operating System Version 5.10.70
CPU Architecture x86_64
Timezone America/Denver
Home Assistant Community Store
GitHub API ok
Github API Calls Remaining 4863
Installed Version 1.15.2
Stage running
Available Repositories 952
Installed Repositories 23
Home Assistant Cloud
Logged In true
Subscription Expiration October 25, 2021, 6:00 PM
Relayer Connected true
Remote Enabled true
Remote Connected true
Alexa Enabled true
Google Enabled true
Remote Server us-xxxxxxxxx.xx.xxxx.xxxx
Reach Certificate Server ok
Reach Authentication Server ok
Reach Home Assistant Cloud ok
Home Assistant Supervisor
Host Operating System Home Assistant OS 6.5
Update Channel stable
Supervisor Version supervisor-2021.10.0
Docker Version 20.10.7
Disk Total 93.8 GB
Disk Used 11.0 GB
Healthy true
Supported true
Board ova
Supervisor API ok
Version API ok
Installed Add-ons Terminal & SSH (9.2.1), Log Viewer (0.12.0), Z-Wave JS (0.1.45), AppDaemon 4 (0.7.0), Check Home Assistant configuration (3.9.0), Samba share (9.5.1)
its on windows latest offical build from the homeassistant website ethernet is bridged with full premiscuis mode. i also have the dns servers set to 8.8.8.8 9.9.9.9 and 1.1.1.1
ok so aparently the dns setting in the ha cli does not change the dns settings that were causing my issue. to get to those
ha> login
#nmcli con edit “Home Assistant OS default”
set ipv4.dns 8.8.8.8
save
quit
ha host reboot
it should reboot and the cycle will break. also you can replace 8.8.8.8 with 9.9.9.9 or 1.1.1.1 depending on your prefrence
Neat, where can i find this information?
it was passed on to me in the discord. to my noladge there is no documentation for it othewr than what was provided to me and posted above
