Initially although I had performed the chown on homeassistant, everything created in the directory was own by root. I chowned that to homeassistant, but it made no difference.
What have I done wrong?
Before continuing with switching to homeassistant user and installing. This installed home assistant, but then I got an error when running (output of homeassistant.log)
2017-12-10 09:37:14 WARNING (Thread-10) [homeassistant.components.light.hue] Connected to Hue at 192.168.0.10 but not registered.
2017-12-10 09:45:01 ERROR (MainThread) [aiohttp.server] Error handling request
File "/srv/homeassistant/lib/python3.5/site-packages/aiohttp/web_protocol.py", line 271, in data_received
messages, upgraded, tail = self._request_parser.feed_data(data)
File "aiohttp\_http_parser.pyx", line 295, in aiohttp._http_parser.HttpParser.feed_data
aiohttp.http_exceptions.BadStatusLine: invalid HTTP method
And I’ve got no clue about what to do about that. Did I screw everything up? Anyone have any ideas?
I still have issues when changing to homeassistant user before making /srv/homeassistant a virtualenv. Could it be because I upgraded to python 3.6.3 before starting (basically using this guide; upgrading python version seems to work fine)?
I will test with a clean Raspbian Stretch Lite installation (python 3.5) when I have time.
Its unlikely different versions of python would cause a permissions problem.
The new instructions do specify changing the ownership of /srv/homeassistant to homeassistant user immediately after creating it, and then creating the virtual environment as homeassistant user, which should avoid permissions problems.
I can confirm that the new instructions work with Raspbian Stretch Lite. It also works after upgrading to python3.6.3, but I then get an error in the log:
2017-12-16 12:15:04 ERROR (MainThread) [aiohttp.server] Error handling request
File "/srv/homeassistant/lib/python3.6/site-packages/aiohttp/web_protocol.py", line 271, in data_received
Not sure what the effect is; I haven’t set up my old configuration yet. So far, I haven’t found anything not working.
