Wanted to set up the new hassos on a second pi3b and get it working before I switched from my main setup.
Tried lots of fresh setup all with the same result. I see the installing wait 20mins screen then after an hour or so the page is not accessable tried rebooting with no difference.
I have tried
32bit version 1.7 hassos
64bit version 1.7 hassos
32bit version 1.9 hassos
And
1.1 resinos (this is the version running on my main setup)
Swapping the working SD card between Pi’s and both work fine.
I have seen other posts with similar issues installing hassos but I don’t even seem to be able to use resinos.
I also can’t think why this is a problem but I never say never.
Did you have to set one up change its port and then add the second or is there a way I can access the config without access to the UI (so not set up SSH or samba)
Seem to have solved the issue with a 3rd SD card. It seems reliable as well as I have now reinstall several time due to my next issue with restoring my snapshot.
