Hi everyone, I recently installed Home Assistant, at the moment I’m trying to do the customization with Windows, trying to install Samba it can’t open Windows Explorer but it opens the H page, how do I do it? I’m trying to install hacs but without success the community store page comes up, how do I solve it? A thousand thanks
Please be more specific
If the community store page comes up, HACS is installed.
yes exactly, I can’t open the page because the ha site opens directly, what do I do? ok installed it’s fine but seeing the videos I should have something else instead of that
- for HACS, you probably enabled experimental features
- for samba, try to map a network drive
There isn’t that feature on Windows 11, how do I find it? There is connect network drive but it doesn’t work
I’ll have to startup a Windows 11 VM
Hi Pietro, welcome to the forum!
What do you mean by?
If Samba is installed on HA and configured, you should be able to see that share.
What if you do ‘Windows button + R’ and type \\‘your HA IP’
it says impossible to log in, sorry you’re right, I’m Italian and I’m using the translator, how do I solve it
See above.
If you see the share, you have to provide the right credentials (user + password from Samba) with ‘connect using different credentials’ as Francis shows in his snapshot.
ah great, it worked now, thank you very much ![]()
Pietro, please take the time to mark the right answer as solution, you do that by selecting the three dots under the post:
Then select the check box:
By doing so this can be useful to other users as well and prevents that someone else steps in and still tries to help you.
