Good morning everyone,
I installed HA on virtualbox. I downloaded the HA here
HA running but I don’t understand how can I add mqtt and zigbee2mqtt on my HA. I didn’t find any information regarding that. Can someone give me some links or more informations?
Thank you so much
ps. I apologize if this one is not the correct section to get these informations.
I suppose this one is HASSIO and I suppose there is supervisor link but there isn’t. What have I missing? there is another way to install on VirtualBox and obtain HA OS?
Check if there is some repairs to be done
Settings → System → Repairs
And in the same place click the three dots in the upper right corner and choose System information.
The scroll down and check the values for Healthy and Supported.
Hi Wally,
on repair page nothing. On system information
Version core-2023.2.5
Installation Type Home Assistant Container
Development false
Supervisor false
Docker true
User root
Virtual Environment false
Python Version 3.10.7
Operating System Family Linux
Operating System Version 5.15.90
CPU Architecture x86_64
Timezone UTC
Configuration Directory /config
cloud
Logged In false
Reach Certificate Server ok
Reach Authentication Server ok
Reach Home Assistant Cloud ok
lovelace
Dashboards 1
Resources 0
Mode auto-gen
recorder
Oldest Run Start Time 23 February 2023 at 08:22
Current Run Start Time 23 February 2023 at 11:14
Estimated Database Size (MiB) 0.26 MiB
Database Engine sqlite
Database Version 3.38.5
You are running a container installation.
According to the Installation link I posted earlier then this installation method does not support addons.
You will have to manage addon containers yourself, which I have no clue on how to do.
Others will have to help here.
Only HAOS and Supervised on Debian 11 installation methods support addons managed by HA.
Thank you Wally… but just a question… There is a guide how to install HASSIO supervisor or OS into a virtual machine? because what I understand it was in that way I’m going to install OS… I’m trying to find it but I can’t reach it. Thank you so much
