I have suceesfully installed Homeassistant on a VM and now I’m trying to utilize my Zstick. The system don’t seem to recognize the stick.
The path /dev/ttyAMC0 is not right.
ls /dev/tty* reports:
/dev/ttyS0
/dev/ttyS1
/dev/ttyS2
/dev/ttyS3
Tried all the above and initially the stick seemed to be included but when I tried to start the ZWave network nothing happens.
I would be grateful if someone could help out with this.
Are you running the software collection formerly known as HASS.IO?
There’s a nice hardware tab on the Supervisor section that might be helpful if so, it should show some weird glob of text connected as a device if you’ve passed it through to your VM properly. I’ve disconnected mine recently so I don’t remember what it reported as.
I managed to get it working by following the video above. In fact I had not had passed the USB devices to my VM machine.
Another problem I’m trying to resolve now is to get the Samba extension to work.
Seems a bit complicated the whole thing as the extension itself has to be configured with the VM network settings and not with the actual host adapter’s.
Any ideas? Do I have to bridge the actual host adapter with the VM’s under Windows network settings?
