I was running HA core on an OdroidN2+ running ubuntu 20, I foolishly upgraded the OS to ubuntu 22, and found , HA no longer was able to communicated with some , but not all of the devices.
Problem is around MQTT, I’m sure as IOT4 devices would not connect, some Shelly devices were unavailable . The original install of 2022.5.4 used python 3.9. I tried an upgrade and saw a lot of python errors. Strangely in dev tools I could see the Shelly EM power meter readings , but lovelace was marking it as unavailable.
As there was a newer version I reinstalled, all went OK until I ran hass, and then
(homeassistant) odroid@odroid:/srv/homeassistant$ hass
2022-08-30 12:18:51.486 ERROR (MainThread) [root] Uncaught exception
File "/srv/homeassistant/bin/hass", line 8, in <module>
sys.exit(main())
File "/srv/homeassistant/lib/python3.10/site-packages/homeassistant/__main__.py", line 191, in main
exit_code = runner.run(runtime_conf)
File "/srv/homeassistant/lib/python3.10/site-packages/homeassistant/runner.py", line 119, in run
return loop.run_until_complete(setup_and_run_hass(runtime_config))
File "/usr/lib/python3.10/asyncio/base_events.py", line 646, in run_until_complete
return future.result()
File "/srv/homeassistant/lib/python3.10/site-packages/homeassistant/runner.py", line 101, in setup_and_run_hass
hass = await bootstrap.async_setup_hass(runtime_config)
File "/srv/homeassistant/lib/python3.10/site-packages/homeassistant/bootstrap.py", line 143, in async_setup_hass
await async_from_config_dict(config_dict, hass) is not None
File "/srv/homeassistant/lib/python3.10/site-packages/homeassistant/bootstrap.py", line 256, in async_from_config_dict
await _async_set_up_integrations(hass, config)
File "/srv/homeassistant/lib/python3.10/site-packages/homeassistant/bootstrap.py", line 532, in _async_set_up_integrations
recorder.async_initialize_recorder(hass)
File "/srv/homeassistant/lib/python3.10/site-packages/homeassistant/helpers/recorder.py", line 22, in async_initialize_recorder
from homeassistant.components.recorder import const, models
File "/srv/homeassistant/lib/python3.10/site-packages/homeassistant/components/recorder/__init__.py", line 23, in <module>
from . import statistics, websocket_api
File "/srv/homeassistant/lib/python3.10/site-packages/homeassistant/components/recorder/statistics.py", line 17, in <module>
from sqlalchemy import bindparam, func, lambda_stmt, select
ModuleNotFoundError: No module named 'sqlalchemy'
type or paste code here
Does HA function with python3.10 if so is there a workaround , I got the same when I tried to upgrade.
If not back to ubuntu 20, I have other applications on that device so the odroid HA image is no preferred.
help appreciated please.
