Where must i put the custom components.
Depends on what this custom component is capable of.
Which custom component do you want to install? Usually thereāre instrucion in the repository that will guide you.
The garbage calendar
Although you seem not as a man of many words a link or 2-3 words more would probably help to help you.
Welcome to the forum btw.
Do you mean Garbage Collection? Instructions are in the GitHub repository. Or do you mean Waste Collection Schedule? Instruction are in there, too.
Yes Github where you get it from or HACS⦠will have instructions. Take from a guy that has had to learn the VERY hardway⦠please read every line of the instructions. I struggled with something for a week⦠NOW had I read āpanel viewā⦠like I totally skipped that part⦠things would have gone smoothly because the minute I did what I was supposed to do⦠VIOLA⦠it worked exactly as it should have. I have a VERY annoying habit of not reading thingsā¦
If I try something and itās not working I go back and read it again⦠if Iām sure Iāve read everything and still have a problem then I ask. Not saying you shouldnāt ask as Iām sure youāre smarter then I am
Iāve had my HA running a couple years now⦠Thanks to a good friend who has held my hand all this time. Itās just been recently that Iām trying things on my own to learn this better. Heās still there but unless I get really stuck he just watches from the background.
Reading and learning is the best thing to do! And Welcome!
Hello
i try and read and try but i cant come any further
Tried to install the garbage-collection.
first I tried it with the garbage-collection folder in Config/custom_components,
then home assistant restarted,
then looked at me addons and at my integrations but there it is not visible.
then tried to add it via respositories there I filled in GitHub - amaximus/garbage-collection-card: Custom Lovelace card for Garbage Collection custom component but then I got this message
Invalid Add-on repository!
Sorry for the bad english
Did you followed the instructions for that on the Github page ?
Do āNoticeā this is a Garbage-Collection-Card , that you can use for the Garbage-Collection Integration
PS: So first you follow the instructions for Garbage-Collection ⦠Then you can Follow the instructions for Garbage-Collection-Card
i follow the instuctions for the garbage-collection but i cant fint it?
go to /Settings/Devices-Integrations ⦠if itās not there(after restart) try to ADD Integration( and search for it ) there.
( PS: i actually donāt remember these steps, as i installed HACS after 1 or 2 Custom Components, much easier there to either search in HACS repository, or just Add the URL, to external/custom github ārepositoryā ) ⦠but even when downloading through HACS, you have to ADD, the integrations, as above.
PS: And followed the āmanualā instructions in regards to āConfiguration.yamlā for the specific integration, if not ādownloadedā via HACS, as this āpartā is usually done by HACS
