I’ve installed Custom-UI with the installer from GitHub, all the files are in place. But when I enable the config section in my configuration.yaml and ctrl-refresh my page… All is gone?!? Instead of a login screen I get only a blue bar on top.
frontend:
extra_html_url:
- /local/custom_ui/state-card-custom-ui.html # when enabled, noting in configuration pop-up
- /config/www/custom_ui/state-card-custom-ui.html # when enabled, blue bar appears
PS: I’m using docker, /config is mapped to ~/.home-assistant
I don’t think so, you can make your logger display more information. I complained about not having a debug for the JS, CSS, and HTML and all I got back was a snide comment about reading documentation by some other user. I don’t think there is a good way to debug any of these custom UI components. If you find one let me know!
