Hi
I cant install dsmr reader …
Im running hass os on rasp pi 4
Itried teh dsmr “smart meter” config, but its less advanced so i want to use dsmr reader
i tried to use docker compose but its not installed and i cant install it
any idea how i get dsmr reader installed?
The first 3 gives error: sudo apt no such file or command
the last one begins installing, then i get error
ERROR: Command errored out with exit status 1:
command: /usr/bin/python3 /usr/lib/python3.8/site-packages/pip install --igno re-installed --no-user --prefix /tmp/pip-build-env-tjw3otra/overlay --no-warn-sc ript-location --no-binary :none: --only-binary :none: -i https://pypi.org/simple -- 'setuptools>=40.8.0' wheel 'cffi>=1.1; python_implementation != '"'"'PyPy'"' "''
cwd: None
Complete output (86 lines):
Collecting setuptools>=40.8.0
Downloading setuptools-52.0.0-py3-none-any.whl (784 kB)
Collecting wheel
Downloading wheel-0.36.2-py2.py3-none-any.whl (35 kB)
Collecting cffi>=1.1
Downloading cffi-1.14.4.tar.gz (471 kB)
Collecting pycparser
Downloading pycparser-2.20-py2.py3-none-any.whl (112 kB)
Using legacy setup.py install for cffi, since package 'wheel' is not installed .
Installing collected packages: setuptools, wheel, pycparser, cffi
Running setup.py install for cffi: started
Running setup.py install for cffi: finished with status 'error'
command: /usr/bin/python3 -u -c 'import sys, setuptools, tokenize; sys.ar gv[0] = '"'"'/tmp/pip-install-3v7htn7e/cffi/setup.py'"'"'; __file__='"'"'/tmp/pi p-install-3v7htn7e/cffi/setup.py'"'"';f=getattr(tokenize, '"'"'open'"'"', open)( __file__);code=f.read().replace('"'"'\r\n'"'"', '"'"'\n'"'"');f.close();exec(com pile(code, __file__, '"'"'exec'"'"'))' install --record /tmp/pip-record-y0fk8ugb /install-record.txt --single-version-externally-managed --prefix /tmp/pip-build- env-tjw3otra/overlay --compile --install-headers /tmp/pip-build-env-tjw3otra/ove rlay/include/python3.8/cffi
cwd: /tmp/pip-install-3v7htn7e/cffi/
Complete output (68 lines):
Package libffi was not found in the pkg-config search path.
Perhaps you should add the directory containing `libffi.pc'
to the PKG_CONFIG_PATH environment variable
Package 'libffi', required by 'virtual:world', not found
unable to execute 'gcc': No such file or directory
No working compiler found, or bogus compiler options passed to
the compiler from Python's standard "distutils" module. See
the error messages above. Likely, the problem is not related
to CFFI but generic to the setup.py of any Python package that
tries to compile C code. (Hints: on OS/X 10.8, for errors about
-mno-fused-madd see http://stackoverflow.com/questions/22313407/
Otherwise, see https://wiki.python.org/moin/CompLangPython or
the IRC channel #python on irc.freenode.net.)
Trying to continue anyway. If you are trying to install CFFI from
a build done in a different context, you can ignore this warning.
running install
running build
running build_py
creating build
creating build/lib.linux-aarch64-3.8
creating build/lib.linux-aarch64-3.8/cffi
copying cffi/ffiplatform.py -> build/lib.linux-aarch64-3.8/cffi
copying cffi/recompiler.py -> build/lib.linux-aarch64-3.8/cffi
copying cffi/error.py -> build/lib.linux-aarch64-3.8/cffi
copying cffi/__init__.py -> build/lib.linux-aarch64-3.8/cffi
copying cffi/backend_ctypes.py -> build/lib.linux-aarch64-3.8/cffi
copying cffi/pkgconfig.py -> build/lib.linux-aarch64-3.8/cffi
copying cffi/commontypes.py -> build/lib.linux-aarch64-3.8/cffi
copying cffi/model.py -> build/lib.linux-aarch64-3.8/cffi
copying cffi/vengine_cpy.py -> build/lib.linux-aarch64-3.8/cffi
copying cffi/setuptools_ext.py -> build/lib.linux-aarch64-3.8/cffi
copying cffi/cparser.py -> build/lib.linux-aarch64-3.8/cffi
copying cffi/api.py -> build/lib.linux-aarch64-3.8/cffi
copying cffi/vengine_gen.py -> build/lib.linux-aarch64-3.8/cffi
copying cffi/lock.py -> build/lib.linux-aarch64-3.8/cffi
copying cffi/verifier.py -> build/lib.linux-aarch64-3.8/cffi
copying cffi/cffi_opcode.py -> build/lib.linux-aarch64-3.8/cffi
copying cffi/_cffi_include.h -> build/lib.linux-aarch64-3.8/cffi
copying cffi/parse_c_type.h -> build/lib.linux-aarch64-3.8/cffi
copying cffi/_embedding.h -> build/lib.linux-aarch64-3.8/cffi
copying cffi/_cffi_errors.h -> build/lib.linux-aarch64-3.8/cffi
running build_ext
building '_cffi_backend' extension
creating build/temp.linux-aarch64-3.8
creating build/temp.linux-aarch64-3.8/c
gcc -Wno-unused-result -Wsign-compare -DNDEBUG -g -fwrapv -O3 -Wall -g -fn o-semantic-interposition -g -fno-semantic-interposition -g -fno-semantic-interpo sition -DTHREAD_STACK_SIZE=0x100000 -fPIC -I/usr/include/ffi -I/usr/include/libf fi -I/usr/include/python3.8 -c c/_cffi_backend.c -o build/temp.linux-aarch64-3.8 /c/_cffi_backend.o
error: command 'gcc' failed with exit status 1
ERROR: Command errored out with exit status 1: /usr/bin/python3 -u -c 'import sys, setuptools, tokenize; sys.argv[0] = '"'"'/tmp/pip-install-3v7htn7e/cffi/set up.py'"'"'; __file__='"'"'/tmp/pip-install-3v7htn7e/cffi/setup.py'"'"';f=getattr (tokenize, '"'"'open'"'"', open)(__file__);code=f.read().replace('"'"'\r\n'"'"', '"'"'\n'"'"');f.close();exec(compile(code, __file__, '"'"'exec'"'"'))' install --record /tmp/pip-record-y0fk8ugb/install-record.txt --single-version-externally -managed --prefix /tmp/pip-build-env-tjw3otra/overlay --compile --install-header s /tmp/pip-build-env-tjw3otra/overlay/include/python3.8/cffi Check the logs for full command output.
ERROR: Command errored out with exit status 1: /usr/bin/python3 /usr/lib/python3 .8/site-packages/pip install --ignore-installed --no-user --prefix /tmp/pip-buil d-env-tjw3otra/overlay --no-warn-script-location --no-binary :none: --only-binar y :none: -i https://pypi.org/simple -- 'setuptools>=40.8.0' wheel 'cffi>=1.1; py thon_implementation != '"'"'PyPy'"'"'' Check the logs for full command output.
I don’t use Home Assistant OS, I can’t help with that. But in Portainer, you can create “stacks”, using docker-compose file format version 2. Might be sufficient.
Possible to explain that to me cause its beyond my knowledge.When i look into portainer i can create stack
and theres a webeditor i should paste this in?
If they don’t exist, create them first using mkdir.
Hope DSMR is nothing of importance, as this setup is wacky your knowledge on what is actually going on is poor. It will probably run, but don’t blame me if things get messy.
The path is abolute, so not inside /home. It’s computed from the path Portainer uses as “home” directory and the realtive path defined in the docker-compose file (see volumes: section).
If you want that directory be created inside a user’s home directory, change “./dsmrdb” and “./dsmr_backups” in docker-compose / portainer stack file to absolute paths, using a user’s home directory.
