Install failing and loops on RPI4
I have been trying to install on an RPI4 and the install process gets into a loop downloading the docker image and installing it. Have flashed 9.2 and 9.0rc2 on the SD card (separately) and both images end up having a similar behavior. Unsure how to proceed so please help. Logs below:
[supervisor.supervisor] Update Supervisor to version 2022.10.0
22-10-18 23:34:30 INFO (SyncWorker_1) [supervisor.docker.interface] Downloading docker image ghcr.io/home-assistant/aarch64-hassio-supervisor with tag 2022.10.0.
22-10-18 23:40:46 ERROR (SyncWorker_1) [supervisor.docker.interface] Can't install ghcr.io/home-assistant/aarch64-hassio-supervisor:2022.10.0: 500 Server Error for http+docker://localhost/v1.41/images/create?tag=2022.10.0&fromImage=ghcr.io%2Fhome-assistant%2Faarch64-hassio-supervisor&platform=linux%2Farm64: Internal Server Error ("Get "https://ghcr.io/v2/": net/http: request canceled while waiting for connection (Client.Timeout exceeded while awaiting headers)")
22-10-18 23:40:46 INFO (MainThread) [supervisor.resolution.module] Create new issue IssueType.UPDATE_FAILED - ContextType.SUPERVISOR / None
22-10-18 23:40:46 ERROR (MainThread) [supervisor.supervisor] Update of Supervisor failed: Can't install ghcr.io/home-assistant/aarch64-hassio-supervisor:2022.10.0: 500 Server Error for http+docker://localhost/v1.41/images/create?tag=2022.10.0&fromImage=ghcr.io%2Fhome-assistant%2Faarch64-hassio-supervisor&platform=linux%2Farm64: Internal Server Error ("Get "https://ghcr.io/v2/": net/http: request canceled while waiting for connection (Client.Timeout exceeded while awaiting headers)")
22-10-18 23:40:46 CRITICAL (MainThread) [supervisor.core] Can't update Supervisor! This will break some Add-ons or affect future versions of Home Assistant!
22-10-18 23:40:46 INFO (MainThread) [supervisor.addons] Phase 'AddonStartup.INITIALIZE' starting 0 add-ons
22-10-18 23:40:46 INFO (MainThread) [supervisor.addons] Phase 'AddonStartup.SYSTEM' starting 0 add-ons
22-10-18 23:40:46 INFO (MainThread) [supervisor.addons] Phase 'AddonStartup.SERVICES' starting 0 add-ons
22-10-18 23:40:46 INFO (MainThread) [supervisor.core] Skiping start of Home Assistant
22-10-18 23:40:46 INFO (MainThread) [supervisor.addons] Phase 'AddonStartup.APPLICATION' starting 0 add-ons
22-10-18 23:40:46 INFO (MainThread) [supervisor.misc.tasks] All core tasks are scheduled
22-10-18 23:40:46 INFO (MainThread) [supervisor.core] Supervisor is up and running
22-10-18 23:40:46 INFO (MainThread) [supervisor.homeassistant.core] Home Assistant setup
22-10-18 23:40:46 INFO (MainThread) [supervisor.host.info] Updating local host information
22-10-18 23:40:46 INFO (SyncWorker_1) [supervisor.docker.interface] Updating image ghcr.io/home-assistant/raspberrypi4-64-homeassistant:landingpage to ghcr.io/home-assistant/raspberrypi4-64-homeassistant:2022.10.4
22-10-18 23:40:46 INFO (MainThread) [supervisor.updater] Fetching update data from https://version.home-assistant.io/stable.json
22-10-18 23:40:46 INFO (SyncWorker_1) [supervisor.docker.interface] Downloading docker image ghcr.io/home-assistant/raspberrypi4-64-homeassistant with tag 2022.10.4.
22-10-18 23:40:46 INFO (MainThread) [supervisor.resolution.check] Starting system checks with state CoreState.RUNNING
22-10-18 23:40:46 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.SECURITY/ContextType.CORE
22-10-18 23:40:46 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.IPV4_CONNECTION_PROBLEM/ContextType.SYSTEM
22-10-18 23:40:46 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.TRUST/ContextType.SUPERVISOR
22-10-18 23:40:46 INFO (MainThread) [supervisor.host.services] Updating service information
22-10-18 23:40:46 INFO (MainThread) [supervisor.host.network] Updating local network information
22-10-18 23:40:47 INFO (MainThread) [supervisor.host.sound] Updating PulseAudio information
22-10-18 23:40:47 INFO (MainThread) [supervisor.host.manager] Host information reload completed
22-10-18 23:40:52 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.PWNED/ContextType.ADDON
22-10-18 23:40:52 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.DNS_SERVER_FAILED/ContextType.DNS_SERVER
22-10-18 23:40:52 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.DNS_SERVER_IPV6_ERROR/ContextType.DNS_SERVER
22-10-18 23:40:52 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.FREE_SPACE/ContextType.SYSTEM
22-10-18 23:40:52 INFO (MainThread) [supervisor.resolution.module] Create new suggestion SuggestionType.CREATE_FULL_BACKUP - ContextType.SYSTEM / None
22-10-18 23:40:52 INFO (MainThread) [supervisor.resolution.check] System checks complete
22-10-18 23:40:52 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state CoreState.RUNNING
22-10-18 23:40:54 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
22-10-18 23:40:54 INFO (MainThread) [supervisor.jobs] 'ResolutionFixup.run_autofix' blocked from execution, system is not healthy
22-10-18 23:46:51 ERROR (SyncWorker_1) [supervisor.docker.interface] Can't install ghcr.io/home-assistant/raspberrypi4-64-homeassistant:2022.10.4: 500 Server Error for http+docker://localhost/v1.41/images/create?tag=2022.10.4&fromImage=ghcr.io%2Fhome-assistant%2Fraspberrypi4-64-homeassistant&platform=linux%2Farm64: Internal Server Error ("Get "https://ghcr.io/v2/": net/http: request canceled while waiting for connection (Client.Timeout exceeded while awaiting headers)")
22-10-18 23:46:51 WARNING (MainThread) [supervisor.homeassistant.core] Error on Home Assistant installation. Retry in 30sec
22-10-18 23:47:21 INFO (SyncWorker_2) [supervisor.docker.interface] Updating image ghcr.io/home-assistant/raspberrypi4-64-homeassistant:landingpage to ghcr.io/home-assistant/raspberrypi4-64-homeassistant:2022.10.4
22-10-18 23:47:21 INFO (SyncWorker_2) [supervisor.docker.interface] Downloading docker image ghcr.io/home-assistant/raspberrypi4-64-homeassistant with tag 2022.10.4.
