I’m unable to get the Fan of the Argon one M.2 working
System: PI4 8GB with SSD in Argon one M.2 - Home assistant 2021.10.6
ArgonOne Active Cooling Current version: 24.1 Installed via Supervisor (seems ok)
Next i tried to enable I2C VIA HOME ASSISTANT OPERATING SYSTEM TERMINAL
https://www.home-assistant.io/common-tasks/os#enable-i2c
No messages when using SDA1 (in contrary to sdb1 or Mmcblk0p1)
In the home assistant log-file i get this log:
[s6-init] making user provided files available at /var/run/s6/etc...exited 0.
[s6-init] ensuring user provided files have correct perms...exited 0.
[fix-attrs.d] applying ownership & permissions fixes...
[fix-attrs.d] done.
[cont-init.d] executing container initialization scripts...
[cont-init.d] 00-banner.sh: executing...
Add-on: ArgonOne Active Cooling
Actively keeping your Argon One cool.
Add-on version: 24.1
You are running the latest version of this add-on.
System: Home Assistant OS 6.5 (aarch64 / raspberrypi4-64)
Home Assistant Core: 2021.10.6
Home Assistant Supervisor: 2021.10.6
Please, share the above information when looking for help
or support in, e.g., GitHub, forums or the Discord chat.
[cont-init.d] 00-banner.sh: exited 0.
[cont-init.d] 01-log-level.sh: executing...
[cont-init.d] 01-log-level.sh: exited 0.
[cont-init.d] done.
[services.d] starting services
[services.d] done.
Cannot find I2C port. You must enable I2C for this add-on to operate properly
Failed 1: source "$@"
Error: Could not open file `/dev/i2c-1' or `/dev/i2c/1': No such file or directory
[cmd] /run.sh exited 1
[cont-finish.d] executing container finish scripts...
[cont-finish.d] 99-message.sh: executing...
Oops! Something went wrong.
We are so sorry, but something went terribly wrong when
starting or running this add-on.
Be sure to check the log above, line by line, for hints.
[cont-finish.d] 99-message.sh: exited 0.
[cont-finish.d] done.
[s6-finish] waiting for services.
[s6-finish] sending all processes the TERM signal.
I’m not familiar with the linux OS so don’t no where to start…
Please help!
