Install HA with ova file invalid checksum algorithm
I tried to install a fresh install of haos_ova-13.0.ova in a ESXI 8 and get this error:
The provided manifest file is invalid: Invalid OVF checksum algorithm: SHA2-256.
I sew this issue a but is closed:
UPDATED:
Downloaded the haos_ova-13.0.vmdk.zip and manually add the disk to new VM.
Now it’s working!!!
Regards!
I ran into the same issue deploying through vCenter with HAos_ova-14.1 and 14.2. I ended up getting it to deploy without issue by deploying directly on a vmhost instead of through vCenter.
Yep, same here. Seems to be fine after doing it that way.
