Install hass.io on Raspberry Pi4 on SSD
Hi guys,
as I’m worried about the SD-card crash issue, I just bought a P4 (2GB), a USB SATA controller (for Raspberry) and a SSD.
Unforuntately it’s not working out of the box.
I flashed on the SSD hass.io and plugged the sata controller via micro usb to the USB port of the raspberry.
After plugging in the power adapter nothing happens.
I don’t own a micro HDMI cable so I can’t see what’s the problem.
Do I need to configure anything to boot up directly from the SSD?
USB boot is not currently available for the raspberry pi 4 (see Raspberry website).
Regarding hass.io, if you tried HassOS, note that USB boot is not currently available (may be in beta in a few days or weeks)
Sorry but you have to wait
https://www.raspberrypi.org/documentation/hardware/raspberrypi/booteeprom.md
Damn, then I should have bought a 3+ ?
Ok then I will run my old Pi 3 until they will enable USB boot for the PI 4
Thanks for the info/reply @makai
Here you can see if the USB-boot is available. At the time of me writing this message it isn’t.
https://github.com/raspberrypi/rpi-eeprom/blob/45aa4ed42cf558725aa83fbe9624017e60a0caa0/firmware/release-notes.md
Hi
I saw that a beta version of the pi4 ssd boot thing is available. I was trying to follow this guide https://www.youtube.com/watch?v=zVhYvvrGhMU as I understand hassio is very limited in what functionality that is available, so I guess that this method doesn’t work.
Nice find, I think I may wait until it’s out of beta before going for this on my Raspbian based setup :slight_smile:
I found a link to a fairly simple proceedure to set it up to first boot from the SD card and then switch to the SSD drive.
https://www.element14.com/community/community/raspberry-pi/blog/2019/08/30/quick-sd-to-ssd-on-the-pi-4
Hi Fred
What image did you flash/move to the SSD?
Andreas Spiess has several videos on youtube about different methods of moving installations from a SD to a SSD, but the standard image I used to flash does not use buster, so I can’t make them work.
Also I have a very limited knowledge about linux so I like to find a installation method which is stable and very close to the SD install for stability.
I used the latest pi image and followed the instructions on here to get HASSIO installed on it.
Point me to image you use and I will see if I can figure it out…
Sound good! :slight_smile:
I like to install the standard one from https://www.home-assistant.io/hassio/installation/ for the Pi4.
it doesn’t matter if its 32 or 64 bit.
The Hassio version of the raspberry pi is running on top of a custom version of linux. It doesn’t appear that there is any support for USB boot for the Pi4 at this time.
The link that I followed:
https://www.home-assistant.io/blog/2019/12/17/hassos-release-3/
Even though I do have pi3 to test on, not sure I would follow this as it permanently alters the bios configuration.
At this point I am sticking with the install procedure at: https://community.home-assistant.io/t/install-hassio-on-raspberry-pi-4-raspbian-buster-with-windows-pc/164394
You kind of have to read between the lines for the preparatory commands to execute; but use the final part defined by “SKAL” for the rpi4.
2020-05-15 Add pieeprom-2020-05-15 beta with USB boot
2020-06-03 Bootmode tweaks and fix issue with > 4TB drives - BETA
2020-06-12 Improve handling of multiple bootable USB devices
Thanks for this,
So what’s the current status ?
Will it boot a hass.io image from the ssd without an SD ?
Or does it only boot pi OS ? (new name for raspbian)
Are there instructions someplace ?
Where are the images / files ?
It looks like it has been moved in to stable status today, so shouldn’t take long.
What is status now?
I think you can do it now, I did try. I think the process is:
  1. updating erom(or something like this)
  2. flash Hassio supervised to SSD
  3. connect and boot.
I waiting for a ssd, to arrive from China, before I test.
No, SSD boot of Hassio is not working yet. I do wish that this was supported though.
It is en BETA (https://github.com/home-assistant/operating-system/releases/tag/5.1) .
Have it running from a USB stick without any problems.
Can I flash this version directly to a SSD?
Yes.
First I updated the RPI4 eeprom to support USB boot. Then I flashed the beta version to my USB. I used a different USB to setup the wifi.
Currently Im running on a USB 2 8gb memory stick witch works great.
Edit: There are some talks that only the 64bit version is currently working. I have not tried the 32bit so cannot say if this is correct
